993 Forum 1995-1998
noise & vibration from elect seat track
Old 10-14-2003 | 06:29 PM
EVVRJB's Avatar
EVVRJB
Default noise & vibration from elect seat track
I have recently begun to get some squeaks and a slight vibration at the very back end of the electric seat tracks/rails when moving the seat backwards. Not as much when moving seat fwd.
Any ideas on how to re-lubricate the tracks to calm this or is this a sign of impending doom for the motor, etc?
Old 08-20-2009 | 12:42 AM
fleeflowfly's Avatar
fleeflowfly
4th Gear
Me too! I got the same problem.
I think Jigaloo or wd40 might help.
Let me know if that works.
Old 08-20-2009 | 01:38 PM
Stealth 993's Avatar
Stealth 993
Put the seat all the way back, & use GREESE (never WD40) to lube the rails, not a lot. The move it all the way up & get the back.
Old 08-20-2009 | 03:38 PM
2Many Cars's Avatar
2Many Cars
What Stealth said. WD40 is a water displacer (hense the name) not a true lubricant so it will work for a while then evaporate leaving even less lube than you started with.
Quick Reply: noise & vibration from elect seat track
