993 Forum 1995-1998
Fister frustration
Old 04-11-2016, 02:14 PM
bobbyp
bobbyp's Avatar
Default Fister frustration
Hi Guys,
Read all of the Fister sound and install reviews and got myself a set of stage 2's last year.
Finally got around to installing them a couple of weeks ago and after dealing with the rusted out bolts and getting the flu I finally tried to install ithem this morning.
I have Bischoffs and am having a ridiculously bad time getting the donuts that are attached to the cats to slide over to the Fister end so I can tighten it down.
Car is on stands and wheels are off. Right now the cat and Fister are together but moving the donut just pushes the muffler away from the cat.
Hopefully I'm just demonstrating my lack of automotive mechanical abilities and doing something dumb.
What do I need to do...
Pry open the donut?
Get another set of hands?
Just keep working at it?
view from bottom (left side of car)
rear view
Old 04-11-2016, 02:18 PM
gt3'er
gt3'er's Avatar
Sorry - not sure. Darin installed mine in about 45 minutes - didn't have any issues. But, rest assured, you will love the result!
Old 04-11-2016, 02:27 PM
nine9six
nine9six's Avatar
bobby,
Those clamps need to be spread, otherwise its a battle...
I used a piece of 1/4" threaded running stock, thru the fastener portion of the clamp, with 2 nuts threaded onto the stock, threading the nuts away from each other, to open the clamp. Hope you can picture this.
p.s. There is no spreading the donut!
Old 04-11-2016, 02:37 PM
cgfen
cgfen's Avatar
Originally Posted by bobbyp
Hi Guys,
Pry open the donut?
You will find it very challenging to "pry open the doughnut"
Yes, find a third hand, in my case i used a pair of external lock ring pliers, that worked very well over multiple clamp On - Off cycles.
Old 04-11-2016, 02:40 PM
Foxman
Foxman's Avatar
Yes, it was a PIA getting the left clamp to slide over with my bare hands. A corner of the clamp would keep catching on the muffler, and prevented it from sliding over. Took me twenty minutes and then it suddenly popped on at the right angle. For future install, like nine9six suggests, I purchased a clamp spreader that can spread the clamp properly to slide it. I also found it VERY helpful to loosen the muffler strap to allow some more give while stretching the clamp over.
Old 04-11-2016, 02:43 PM
bobbyp
bobbyp's Avatar
Sorry about my terminology. By donut, I meant camp.
nine9six, I can totally picture your description. Seems like I'll just need to separate it a half inch or so.
If that doesn't work, the retaining ring pliers look like something interesting to add to the tool collection.
Old 04-11-2016, 04:53 PM
Allen
Allen's Avatar
You need to get some Retaining Pliers...can only imagine what a pita it would be without those.
Old 04-11-2016, 06:17 PM
P-daddy
P-daddy's Avatar
Another vote for the lock ring pliers. I've done this at least 2 dozen times and can't imagine doing without it.
Looks like your donut is in place. All is needed is to spread the clamp to cover the lips on the muffler and cat.
Old 04-11-2016, 06:25 PM
nine9six
nine9six's Avatar
This leaves both hands free. The snap ring/retaining ring pliers will work as well and are a must for any tool box. Get a good set; China crap is just that!
P.s. Don't tighten anything, keeping things free to move, but not free enough to separate from the clamps. Also assure the muffler is still in its hanging slot, prior to tightening the muffler band clamp.
Old 04-11-2016, 06:39 PM
AZ Targa
AZ Targa's Avatar
I thought is was somewhat hard with the pliers, I can't imagine doing it without the pliers.
Old 04-11-2016, 07:14 PM
kjr914
kjr914's Avatar
Just go buy the snap ring pliers. After you've put the clamps on in 5 seconds, you will go "WOW that was money WELL spent..." I had bought some "just in case" (and I like buying tools...) and was damn glad to have them when I removed/re-installed mind muffs.
Old 04-11-2016, 07:20 PM
95_993
95_993's Avatar
I just use a big pair of needle nose pliers in reverse. Takes two hands though.
Old 04-11-2016, 08:44 PM
bobbyp
bobbyp's Avatar
WOW that was money WELL spent!
Got a Channellock 927 and maybe not 5 seconds but within 15 seconds I was grinning.
https://www.channellock.com/927-Reta...ing-Plier.aspx
Channellock 927
Old 04-11-2016, 08:50 PM
Mr.Woolery
Mr.Woolery's Avatar
Now I feel all macho, because I did my install bare handed...pried those clamps apart with my fingers. Was tough and hurt my fingertips like hell, but managed to make it work.
Old 04-11-2016, 08:54 PM
Foxman
Foxman's Avatar
:Yup, I picked up one of these Sears Craftsman lock ring pliers. Gives you an inch spread and leaves the other hand free to set the clamp in place. Hoping one inch spread is enough (ok, here come the jokes). Fister II's arrive tomorrow!
Another tip, start with the clamp on the muffler that has the flange. Much easier to slide that down over the cat than the other way around (although you can still slide past it like I did, which is what cost me twenty minutes while prying the darn thing apart bare-handed).
And BobbyP the edge of the clamp does appear to be jamming into the muffler flange which is why the muffler is moving, and the clamp won't go any further. Precisely what I was dealing with, and damn frustrating.
Lock ring pliers
Quick Reply: Fister frustration
