993 Forum 1995-1998
Unconnected vacuum hose
Old 03-28-2016, 08:52 AM
kevin2012
kevin2012's Avatar
Default Unconnected vacuum hose
I found that there are 2 vacuum hoses unconnected under the dash board on my RHD 95 C2. Cheers.
2 unconnect vacuum hoses under the dash in the driver side on my RHD 993.
Old 03-28-2016, 03:13 PM
ToreB
ToreB's Avatar
Resirculation flap actuator hose. The white with rubber bend goes to the actuator.
I have never seen a black vacuum hose under there, so I don't know that.
Cheers,
Tore
Old 03-28-2016, 08:35 PM
kevin2012
kevin2012's Avatar
Thanks ToreB.
Where is the recirculation flap actuator located?
Cheers.
Old 03-29-2016, 02:29 AM
ToreB
ToreB's Avatar
Just above the hos you found.
You see it from below, but also trough the Climate Control Unit dashboard opening.
T
Old 03-29-2016, 02:47 AM
kevin2012
kevin2012's Avatar
Hi Tore, you are also RHD too in Norway? Cheers.
Old 03-29-2016, 02:55 AM
peter y.s pang
peter y.s pang's Avatar
my 993 Tip also RHD, but i don't have such black vacuum tube as well.
Old 03-29-2016, 01:31 PM
kevin2012
kevin2012's Avatar
Sorry that I really cannot find the re-circulation flap actuator under the dash in the driver side. I think that the PO had deleted it and left the vacuum hose unattended. Meanwhile, i will plug the vacuum hose and may I have the part number of this re-circulation flap actuator? I want to refit it.
Cheers.
Old 03-30-2016, 09:28 PM
kjr914
kjr914's Avatar
Cheers.
Have you pulled the Climate Control Unit (CCU) out and looked directly in? I don't recall being able to see it from under the dash.
Look in the online Katalog on the Porsche website:
http://www.porsche.com/all/media/pdf...93_KATALOG.pdf
Looks like it might be a full assembly with vacuum actuator and flap:
flap 993 572 077 00
pdf page 353/437, section 9: Body
Old 03-31-2016, 02:42 AM
kevin2012
kevin2012's Avatar
Thanks. How can I pull the CCU out? By some special tool?
And I don't have heat, is it related to this unconnected hose?
Cheers
Old 04-14-2016, 04:26 PM
ToreB
ToreB's Avatar
I checked now, the black tube is not a vacuum line, but a wire harness tube. It is much softer to touch than the vacuum pipe, and there should be wires in it.
Cheers,
Tore
Old 04-14-2016, 09:22 PM
kjr914
kjr914's Avatar
Cheers
Look at the face of the CCU...there are 2 holes on either side. There are U-shaped wire tools that pull out the unit. Same as used sometimes on car radios, so you could find them anywhere they install car radios.
You can try to cut/bend coat hanger wire to the right size/shape and might work. Or I have this kit I got on Amazon for $10, knowing it would come in handy some day...
Amazon.com: Car Radio Stereo, Dash Removal Install Tools (Set of 12): Cell Phones & Accessories Amazon.com: Car Radio Stereo, Dash Removal Install Tools (Set of 12): Cell Phones & Accessories
Use a bunch of blue masking tape on the dash & steering column to prevent scratches.
Old 04-14-2016, 10:22 PM
Foxman
Foxman's Avatar
Cheers
CCU/Radio removal tools
Old 04-14-2016, 10:48 PM
kevin2012
kevin2012's Avatar
Thanks for the advices. I had pulled out the CCU without damage anything and proved that the re-circulation flap actuator was removed by the PO. As well as the heater related hoses at the engine room. I think it is because I am located in the sub-torpical area where heater is really not a must. Is the black color hardness tube just stay unconnected like that?
Cheers
Quick Reply: Unconnected vacuum hose
