993 Forum 1995-1998
mileage on Bridgestone S02's...(285/30/18)
Old 02-18-2002, 09:42 AM
993RS
993RS's Avatar
Post mileage on Bridgestone S02's...(285/30/18)
Hate to bring this up again... <img src="graemlins/cussing.gif" border="0" alt="[grrrrrrr]" />
But I just read an article stating that S-02's indicate a tread-life of 21,000 miles on the rear. (article did not mention whether 18, 17 or 16 inch wheels were tested...
But heck, I get max. of 4,000 miles on my rears. <img src="graemlins/c.gif" border="0" alt="[ouch]" />
I am not driving like a madman either. <img src="graemlins/nono.gif" border="0" alt="[nono]" />
How about you guys out there driving the same size S-02's as I stated, what kind of mileage are you getting?
Old 02-18-2002, 12:00 PM
Martin S.
Martin S.'s Avatar
Post
I have 17,000 miles on the rears...they are needing replacement. This includes a little track time. It has been a good tire.
Old 02-18-2002, 12:01 PM
Anir
Anir's Avatar
Post
993RS,
I've got tons of tread left (approx. 50-70%) with over 8,000 miles, including 6 track days.
However, they don't grip so well anymore, even with good apparent tread left. I'll probably replace them soon.
Old 02-18-2002, 12:07 PM
Fred R. C4S
Fred R. C4S's Avatar
Post
I just replaced my rear S0-2's. They had approximately 12,500 miles on them. )This included one or two track sessions at Road America. Note, RA is not that hard on tires. Brakes are another matter.)They could have gone a little longer, but as they approach the wear bar limit, the road noise increases noticeably. I project that the fronts will easily reach 25,000 miles. I may replace them sooner if the new rears don't last as long as the first set. I'd like to replace the fronts with every second set of rears.
Alignment and driving style have a significant effect on life. I'm sure that if you "lean on them" at every opportunity, they will wear much faster.
Cheers,
Old 02-18-2002, 12:11 PM
993RS
993RS's Avatar
Post
Anir,
You have a 993TT right? More hp than my 993RS. I guess you are not lowered as much as I am (guessing here), but I still do not see as it can make that much more of a difference. <img src="graemlins/c.gif" border="0" alt="[ouch]" />
I wonder if the US S-02 has a different rubber mixture....
Old 02-18-2002, 12:14 PM
bloke
bloke's Avatar
Post
RS,
how hard are you driving your car? I sounds very low to me. With my old car(M3). I got around 20k for the rear mabye you got a defect but seems like you just drive hard.
Old 02-18-2002, 12:29 PM
Terry Adams
Terry Adams's Avatar
Post
I get about 10K on rears, 25K on fronts. Street only.
Old 02-18-2002, 12:30 PM
Anir
Anir's Avatar
Post
[quote]Originally posted by 993RS:
<strong>Anir,You have a 993TT right? More hp than my 993RS. I guess you are not lowered as much as I am (guessing here), but I still do not see as it can make that much more of a difference. <img src="graemlins/c.gif" border="0" alt="[ouch]" />
I wonder if the US S-02 has a different rubber mixture....</strong><hr></blockquote>
Yes - a 993TT, with the Eibach 7209 lowering springs . Mostly city driving (i.e. putt-putting around ). Don't know about the rubber compounds.
Old 02-18-2002, 12:56 PM
Richard C4S
Richard C4S's Avatar
Post
Would you consider the Michelin pilot sport tire? Seems to have a similar tread pattern to the S02.
-Richard
Old 02-18-2002, 01:15 PM
Ray Calvo
Passed On
Ray Calvo's Avatar
Wink
993RS, either:
a) you have an alignment problem - as I do now on my '95 993 (10K on BFG RE730 rears vs. 20K on BFG Comp T/A; got a funny wear pattern also).
b) you are drivng like the dickens in compar. w/ others.
Old 02-18-2002, 02:06 PM
993RS
993RS's Avatar
Post
Ray,
I have no alignment problems. Car has been set up by a team that sets up Porsches for the Porsche Cup races in Germany. Also the rears are evenly worn out. I do take the car out on lonesome, curvy country roads, but do not approach any limits... <img src="graemlins/cussing.gif" border="0" alt="[grrrrrrr]" />
Richard,
I would consider any tire of similar performance with a better tread life... In fact, just looked up the tirerack web page, and saw that it does have higher tread life rating than the S02, thanks, will look into it.
Old 02-18-2002, 02:54 PM
maurice97C2S
maurice97C2S's Avatar
Wink
RS, you may not have an alignment 'problem', but if your car has been set up to race spec, it will probably have increased toe-in, especially at rear. Track handling is a compromise setting where fast lapping has priority over wear. Look at the different specs in Bruce Anderson's 911 book, take a view where you want to be.
HTH, cheers, Maurice. <img src="graemlins/bigok.gif" border="0" alt="[thumbsup]" />
Old 02-18-2002, 03:05 PM
H20NOO
H20NOO's Avatar
Post
I've got 8,200 on 285/30/18 S02's with a couple auto-x's and many spirited drives. They have about 50% tread left.
If you have a limited slip differential I believe that can significantly reduce tire life. I have the standard diff.
MC
Old 02-18-2002, 03:10 PM
H20NOO
H20NOO's Avatar
Post
One more point... I've seen S-02's and S-02 "Pole Position" tires advertised. Is it possible there are 2 compounds available? A standard S-02 and a softer S-02 "Pole Position"?
Mine do not say "Pole Position" anywhere on the tire. They are simply S-02's.
MC
Old 02-18-2002, 03:34 PM
993RS
993RS's Avatar
Post
Maurice,¨
When I originally bought my car, it was a stock '95 993. I used to get 6,000 miles on my rears at the time. Modifying it to RS specs, brought me down 2,000 miles. Still, my original 6,000 miles is much lower than what you guys are getting on your cars. I remain baffled, befuddled and confused... <img src="graemlins/c.gif" border="0" alt="[ouch]" />
Quick Reply: mileage on Bridgestone S02's...(285/30/18)
