Ashtray light bulb replacement
OK, so I remove the ashtray by (1)removing the ashtray insert; (2)pushing down on the spring hinged "roof" to get to the screws; (3) remove the two phillips head screws.
The ashtray light bulb pulls out of the ashtray wrapped in a rubber grommet.
Do I just pull on the wires and slide out the bulb? It doesn't seem to want to get pulled out and I don't feel like having to order a new piece if I don't have to.
Any experience or suggestions?
Wedge base bulb, pulls straight out. Wrap a bit of duck tape around it if you fingers can't grip it. I replaced it with an LED 74 bulb - see:
https://www.superbrightleds.com/more...rofit-car/228/
Glad you guys were able to work that out.
For anybody who hasn't seen their ashtray light bulb/holder, here is a picture.
Note the screws that need to be removed to take out the ashtray.
