Lifter noise
When it is very cold, my lifters tap for a while. I had the lifters done 3 years ago. I was told to use Castrol 10-60W oil.
It is not a big deal, it goes away as soon as the temperature begins to rise, but wonder how many others have the same problem. I have 100,000 miles on my car.
Thanks.
Thanks.
74K miles here on '95 Carrera - sitting for over a week with cold (40s/50s F) temps produces some lifter clatter for me until engine warmed up - noise gradually subsides and disappears after five minutes of easy run time. Tells me I should drive the car more frequently.
Replaced all of my lifters 3 years ago (one of them twice), use Mobil 1 15/50, at start up ticks like a sewing machine after a few minutes it stops.
RL Technical Advisor
Thanks.
Thanks.
Lifters can make noise if the car sits for a long time and they can bleed down. They can also become noisy when the seals fail or the wrong oil is used.
I'm not a fan of 10w-x oils in these cars for this and other reasons, with the exception being for cars used in arctic conditions. I much prefer a 15w-40 or 15w-50 as I think it helps the oil to cling better; something very important to crankshaft thrust bearings, cams, rocker arms and lifters.
I think oil can make a difference. When I bought my '95 three years ago it had a good "tick" on the left side. I switched to Mobil V-Twin 20W-50 (with a little Mobil 15W-50 mixed in), and the tick lessened. These days I almost never hear the tick anymore which baffles me but I'm not complaining.
Hi Phil!
For arctic conditions, one can use a 5w-40 or 10w-40, provided its been fortified with some additional ZDDP since very few such oils contain enough for these engines.
(if you spun a bearing, that was a totally different issue)
The issue was lubrication not reaching the bearing for multiple engine starts. One bearing failed before the others, but all showed scoring and excessive wear including the mains. I am not suggesting 0W-40 should be used in moderate climates or occasionally driven cars, but in colder climates for daily or frequently driven cars I would consider it.
Bobbo, I have come to accept that engine lubricant brand, viscosity, additive package, change intervals and filters will always be a contentious conservation. I agree that how you drive is one of the many factors, and I also suggest that there is a difference in Lake Tahoe winters and northern Wisconsin winters where my misfortune occurred.
