993 Forum 1995-1998
Rust/Dust inside Distributor
Old Jan 23, 2016 | 04:08 PM
71-3.0-911's Avatar
71-3.0-911
Default Rust/Dust inside Distributor
Has anyone seen this before? I'm sending it off to Steve Weiner shortly but was shocked to find what looks like rust or maybe since its in the belt area, its dust from the belt disintegrating? Thoughts? Had the car about 2 years now and it has 98k and from what I can tell, the distributor has never been rebuilt. Ugh...
Old Jan 24, 2016 | 05:13 PM
2Many Cars's Avatar
2Many Cars
It doesn't look that concerning. They are vented so it's not surprising that over the years some moisture got in there, especially if you live in a humid/wet climate. After over 20 years of heat/cold cycles you get a little surface corrosion.
Old Jan 24, 2016 | 06:39 PM
RBP's Avatar
RBP
Make sure to have all 4 bearings replaced while the unit is apart. Many just do a cleanup and replace the belt. May as well do it right! I had to order my bearings from Germany as I couldn't find any in NA.
Old Jan 25, 2016 | 08:14 AM
pp000830's Avatar
pp000830
Good you caught the issue. I have an antidotal insight I would like others to comment on. When ever I replace the cap and rotor I lube the mechanism and put a few drops of oil on the rotor shafts. Not sure if this helps longevity but my feeling is if the bearing seals are a little weak the presence of a little oil will forestall lubrication related failures. In the old days of mechanical points I seem to recall this was standard procedure.
Old Jan 25, 2016 | 01:52 PM
Steve Weiner-Rennsport Systems's Avatar
RL Technical Advisor
Good man! Its still a valid and necessary part of the maintenance program.
One is supposed to put a several drops of motor oil onto the felt pad you see at the top of the shaft every year or so. This lubricates the weights and springs (for rotor phasing) to prevent them from freezing up from corrosion.
Old Jan 25, 2016 | 02:31 PM
Rockit's Avatar
Rockit
Great idea !!
Check if the car stored by the coast, it would have to be right on a or a few blocks away? Also check for signs around the engine and under the carpets if the car was in a flood? Fresh water is fine.
Old Jan 25, 2016 | 03:28 PM
Magdaddy's Avatar
Magdaddy
Wow...never heard that one before. So, whatever motor oil were using for the car is fine..define several, like 3-4 drops?
Old Jan 25, 2016 | 07:32 PM
This is something I learned back in the early 60's when I started. Old school stuff.
Yep,...any engine oil will do. I usually get it pretty damp with 10-15 drops or so.
Old Jan 25, 2016 | 08:37 PM
71-3.0-911's Avatar
71-3.0-911
Thanks for all the help guys. Got the distributor off in the mail to Steve now. Can't wait to see the improvement.
