Buying RUF 993 (long), Any Advices? (3 pics)
Hi,
Info. on this car from the owner. Any thoughts on this? Pics to follow shortly. Thanks.
CP
RUF 993 BTR-2
Car is a 1995 U.S. spec. C2, black/black. RUF BTR (class B, single Turbo RUF) conversion performed in August 2000. All work by the RUF Company in Germany. Since the conversion, the car has traveled about 25,000 miles.
ENGINE
When RUF did the BTR conversion, the engine was taken out, torn down and completely rebuilt according to their specifications. Warn parts, including all bearings, were replaced. The connecting rods were replaced with titanium ones for strength and reliability and are free-revving, resulting in less weight and less stress on the block. Maximum boost = 1 bar. Car has a second oil cooler at front left tower brace. Motronics ECU, high-flow injectors, special RUF free-flow metal cat exhaust, RUF intake plenum and K&N filter, RUF wiring harness.
Motor produces 426 HP with a single turbo as in the 965 turbo. Torque is 435 ft. lbs (590 NM). Compression is reduced to 8.4:1. Car weights less than 3,000 lbs with some light-weight components. (flywheel, seats, wheels, etc.) That’s an incredible 7 lbs/hp. Virtually no turbo lag, this is the genius of RUF cars. 0-60 time about 3.7 seconds, top speed between 192 and 196 MPH (RUF spec. is 308 km/hr, 192 mph.)
TRANSMISSION
RUF 6 speed transmission with longer 5th and 6th gears for higher top speed. Lightweight flywheel, heavy duty RS clutch, and a heavy duty pressure plate to handle the immense torque. Rear wheel drive, automatic Brake Differential, (ABD) ABS and limited slip differential. Short shifter, and RUF steering rack.
SUSPENSION & BODY WORK
RUF-lowered (30mm) suspension with RUF springs and Bilstein shocks. RUF sway bars, new front end RS bushings, tie-rod ends, ball joints and A-arms. 993 RS side skirts and front corner spoilers with Tech-Art grill insert. Turbo-S rear spoiler. Polished RUF exhaust pipes with RUF inscriptions.
BRAKES, WHEELS AND TIRES
RUF Turbo brakes (322 mm), stainless steel brake lines, RUF logo calipers.
RUF 18" light-weight racing wheels by OZ, painted body color (metallic black), center caps with RUF logo in gold. Anodized aluminum wheel spacers (5mm). Like new Bridgestone S-03 Pole position tires: 235-40/ZR 18 front and 265-35ZR/18 rear. 285-35ZR/18 can be used also. Rear fenders flared slightly to accommodate the wider tires.
ADDITIONAL GOODIES
The car has a 14" 3-spoke Atiwa sport steering wheel. Recaro (A-8) water buffalo hide seats. These seats are available in Europe in the GT2 and GT3 as a Porsche option, but not available in the States. Removable 4-point Schroth racing belts. RUF Aluminum pedals. Tear-drop shaped carbon-fiber sport mirrors, aerodynamic A-pillar inserts to reduce air drag. Deluxe Blaupunkt CD Radio, 10 speakers. Sunroof, A/C, stainless steel threshold plates. Taller top gears, aero body work, light-weight components, and narrow-body style result in higher top-speed than spec.
One original owner, accident, ding and dent free, US title and certificate of origin. Serviced by RUF, 30,000 miles service just performed
CP
RUF 993 BTR-2
ENGINE
TRANSMISSION
ADDITIONAL GOODIES
Mucho buy it! Replace the "gold" parts, put on some bigger rear tires, lower it some more and drive the wheels off of it. (You also may want to re-gear it for American roads, as it is set up for the Autobahn...)
Jim,
I believe the 'gold' parts came as a RUF package. The outside RUF logos (front, and rear), dash bezels, counsel plates, and RUF floor mat logos all came in the same color.
Pin,
This is subject to PPI still. When is the next BAR drive?
CP
Pin,
CP
Phlat Black Guru
Lifetime Member
- Times 2
Lifetime Member
- Times 2
1 Post
Nice, I really like the black on black on black look!
Why regear for the usa roads? I am pretty sure most, or at least a few of us "usa" guys regear for euro roads????
King of Cool
Nice!
I don't like the gold parts either but since they came with that RUF package originally, I'd keep them as is.
I wouldn't re-gear either. This thing has enough "tilt" with the gears it has now and who knows, little trip to Arizona where they have these open road things and you might find the 6th gear really useful!
When I first saw the gold bezels, I thought it was a little gaudy. I ask the owner and he explained the Ruf color package. I also realize that black-on-black is very 'uniform' color-wise. It is also quite common. This is a unique car, and this gold touch adds to it's uniqueness. It actually is growing on me now, especailly realizing that the color is co-ordinated on different parts of the car.
As for the gearing. While I do not race (street or track) but I gather most races will be over with if I run out of fourth gear in a RUF. Thus taller 5th and 6th gear won't hurt much. In addition, with two oil coolers and titanium innerds and one-bar boost, this car is ready for higher boost and thus more power. In that case, the taller top gears will mean evev higher top speed, which is fine by me.
I'm not thinking of modding the car. With my local traffic, I can't use the 426 hp as is. This is a weekend car for the country/twisty roads, so more hp does not add up to more fun. But in case someone else wants more, it's ready for it.
Thanks for your kind words thus far.
CP
CP
Chuck,
I have regular photos, but not digital images. Sorry for now. When the car gets here, I'll post an album with all the revelent shots.
The seat is black plastic shell with black buffalo hide fronts. The seat back has the Recaro logo with the 'A-8" model on it. There are eyelets for the four-point belts. Very pronounced shoulder bolsters. My friend (used to race Porsches) helped my test-drive the car, and said the seats are exactly what this car should have.
CP
CP
GT3 player par excellence
cp, when car here?
can't wait to see it.
we can do the drive again like we did last time.
