993 Forum 1995-1998
Problem - Changing Cap & Rotors
Old Oct 10, 2015 | 02:50 PM
gavonder's Avatar
gavonder
Default Problem - Changing Cap & Rotors
I've done a quick search & didn't see any solutions. I'm trying to remove the plug wires from the cap & they don't budge. This common, & what's the trick?
Old Oct 10, 2015 | 03:00 PM
BobbyT's Avatar
BobbyT
Twist and wriggle the terminal back and forth to break the sticktion, keep tugging. Don't pull on the wire itself.
Old Oct 10, 2015 | 03:23 PM
P-daddy's Avatar
P-daddy
Yes, twist left right a few times to break the seal, grasp the end (not the wires) and pull firmly.
Old Oct 10, 2015 | 03:25 PM
F18drvr's Avatar
F18drvr
And keep repeating "patience" in your mind and don't be afraid to walk away too...pulling the wire off will complicate the simpler task you have under taken...
Patience...
Old Oct 10, 2015 | 04:08 PM
bruce7's Avatar
bruce7
Frustrating yes.
I made a tool to help remove these connections. It is described in posts 9 and 19
in my thread on changing spark plug wires:
https://rennlist.com/forums/993-foru...l#post12444802
https://rennlist.com/forums/993-foru...l#post12477819
You could fabricate one from scratch as well if you couldn't find some other
starting point.
-bruce
Old Oct 10, 2015 | 04:20 PM
gavonder's Avatar
gavonder
Thanks. Caps & rotors done! Makes a difference. Maybe no CEL now.
What a PITA!!
Old Oct 10, 2015 | 05:43 PM
nine9six's Avatar
nine9six
What a PITA!!
Wires are even more fun!
Old Oct 10, 2015 | 06:57 PM
gavonder's Avatar
gavonder
Originally Posted by bruce7
Frustrating yes.
starting point.
-bruce
I read your thread before I started, Thanks.
Old Oct 10, 2015 | 10:17 PM
P-daddy's Avatar
P-daddy
You ain't kidding
Old Oct 10, 2015 | 11:39 PM
gavonder's Avatar
gavonder
Yeah, they look like work! I went for a spirited drive after - so much fun, these cars are amazing! No CEL.
