Oil Return Tubes Replaced
Rockit,
Another way to think about this is that the tube overlap should be oriented like the shingles on a roof, so the liquid flows over rather than into the joint. Installed as they are in your first picture, hot oil will flow down the larger tube and pool against the seal until the volume is sufficient to flow into the smaller tube, and on into the engine. If the tubes are installed with the smaller end in the heads, then the oil will flow directly into the larger tube, with no chance to pool up against the seal--less chance for leakage overall.
I have just purchased a 95 cab with 110,000 miles and it has leaks all over the place not sure where.
1. Did you wash down first to find out where and what was leaking
2 What other seals did you replace
3 I plan on doing plugs is there anything else I should do
4 I will be removing back bumper to do some work on it
5 I will be replacing the exhaust with a Fabspeed package
So I should have a little more room to work
all suggestion will be greatly appreciated
john
john
No I used a lift and could clearly see the leaks.
Valve covers & gaskets, rear main seal, oil tubes, main oil return line to engine, timing cover gromets. It's much easier to remove the engine and do everything.
Look at the service history to tell you what's needed. I did plugs, wires, cap and rotors and also changed the belt in the distributor.
Also look at Fisker stage 2 exhaust. No resonating at hwy speeds, quiet when you cruise and louder when you stomp on it. Fabspeed in my opinion is more for racing. Look up FDmotorsports.com
john
john
I recently bought a 95 C2 Cab and here in the Northeast the roads are not kind to metal.
I had many oil leaks but the oil tubes were the worst. I wanted to post some pics. This was done this morning. If you develop a leak here good news they sell expandable replacement tubes so you don't have to remove the heads.
![](http://i136.photobucket.com/albums/q171/Gmanxs650/993%20oil_zpswbkui2b8.jpg)
![](http://i136.photobucket.com/albums/q171/Gmanxs650/993%20oill_zpsg6w3xzao.jpg)
I used this Harley "high temp silver metallic" on the cases and it looks OEM
![](http://i136.photobucket.com/albums/q171/Gmanxs650/993oillll_zpshifrrwp9.jpg)
![](http://i136.photobucket.com/albums/q171/Gmanxs650/993%20oilll_zpsdlzelnc7.jpg)
Link to "How To" the tubes below
http://www.pelicanparts.com/techarti...turn_Tubes.htm
nine9six,
I think we know the direction of oil flow. Given that the end of the tube at the head is higher than the end at the engine case, the oil, being a liquid, will seek the lower level. The purpose of the tubes is to return oil from the heads to the engine case, hence the name "oil return tubes".
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
KNS was right on target.
