Steel Lug Nuts?
King of Cool
I use them as well, with aluminum wheels and haven't had any problems even though I usually put my track wheels on ~ a week earlier when I go to the track.
Addicted Specialist
Hey all,
I've heard the same advice about using steel lugnuts for trackdays. How necessary is this really (for those not racing). I've got Kumhos on 17"cups and I timetrial, if that's at all relevant. TIA
Edward
Edward
Originally posted by zffnhsn
I use the OE aluminum nuts with 17 in cups and Kumhos. No problemo! Besides, aren't we after unsprung weight?
Kim I use steel lug nuts with the stock 17 cups on the race car.
Darth Cup
Originally posted by Edward
Hey all,
Edward
Hey all,
Edward
![Thumbs up](https://rennlist.com/forums/images/icons/icon14.gif)
One other advantage to open, steel lugs is that you can see how far the threads engage. I believe the Club Race rule is that the engagement amount should be equal to or greater than the width of the studs.
I purchased some BBS race wheels and the centers were actually a bit thicker (~1/2") than the Factory wheels. When mounted, the stud ends only travelled half way through the lugs; to use them safely, I would've needed to install longer studs. Luckily, the seller was a local PCA member who refunded my money.
If you use spacers/shims with stock studs, you might also be running a safety risk. Steel lugs will help determine if that's the case.
I had heard another reason for steel lugs. If you torque a hot alloy lug nut you can damage it. Don't know if it true but since the rules require them it is a non-issue for me.
Boy, Kim, that's a great deal on lug nuts.
I'd suggest you measure the amount of thread engagement to see if it is, in fact, equal to or greater than the width of the studs. The "requirement" comes from the PCA Club Racing Rules but I think if you're participating in other high-speed events, adherence to those guidelines is probably not a bad idea. At least you'll never fail tech at your local PCA DE's.
Are you using spacers or aftermarket wheels?
