Too many codes in the ODBII standard - besides that, these days basic code readers are really cheap - I keep a small one in my door pocket.
Yes, and the plug-in standardized OBDC reader socket design, reader communication protocol, and generic emission code numbers were required by regulation in the US after 1996.
Being the world's largest market, car manufacturers moved from whatever proprietary system they were using to the US standard with added proprietary manufacturer-specific non-emission module codes and extended codes related to the engine.
Andy
Would the codes be the same for a 1993 968? The procedure worked and gave me 1131, knock sensor #1. I haven’t found a dealership or shop within 100 miles that has the connector to read it for me.
Thanks for the great info!
Originally Posted by Gbos1
No. You are in the 993 Forum.
OK, found the codes for the 968. Looks like any number that's in both lists has the same meaning, except for the cylinder numbers on injection valve faults. Then each list has a couple that aren't in the other. So my code is reading knock sensor 1.
I’ve had that and I bet it’s the green connector on top of the engine. Gets heat soaked and wet during washes.
break/make the connector a few times. A squirt of contact cleaner and you should be good for another 25 years
