Check Engine Light, Why
I've noticed if I allow my car (95) to idle for more then 5 minutes my CEL will come on but after I drive her for a mile or so the light goes out, what causes this?
Since the CEL can be anything, probably best to get a code scanner of some sort and find the actual code. Since its a 95 its not one of those SAI problems. Maybe cat efficiency for cooling? Battery/alternator connection issues? Im out of guesses.
You can read the codes on your 1995 without a code reader.
1. Turn on the ignition, but don't start the engine.
2. Depress the accelerator pedal fully for about 3 seconds.
3. The CEL will illuminate steady, and then begin to flash.
4. Ease off the accelerator pedal, and read the codes.
Each code consists of four digits, such as 1121. Each digit will be a number of flashes followed by a pause. Example: Flash pause flash flash flash flash flash = 1500, which means "no fault found". There may be multiple codes. You should have a single flash then a pause, then a single or a double flash. If the flash is double then the fault is intermittent (loose contact) otherwise the fault is constant. And then the following flashes;
11 Supply voltage
14 Engine temp sensor 2
15 Throttle potentiometer
18 Rpm signal
19 Speed signal <- Speedometer
21 Hot Film Mass Air flow sensor
22 Oxygen Sensor (Signal)
23 Oxygen regulation
24 Oxygen sensor
25 Intake Temperature Sensor
26 Ignition timing change
27 Opening winding of idle stabilizer
28 Closing winding of idle stabilizer
31 Knock sensor 1
32 Knock sensor 2
33 Control unit faulty
34 Hall signal
36 Idle CO potentiometer
41 Control unit faulty
42 Fuel pump relay (DME-relay)
43 Tank ventilation relay
44 Air Pump
45 Check Engine warning lamp
51 Injection valve cylinder 1
52 Injection valve cylinder 6
53 Injection valve cylinder 2
54 Injection valve cylinder 4
55 Injection valve cylinder 3
56 Injection valve cylinder 5
67 Ground and plug connections
69 Ground and plug connections
A MAF failure would look like;
FLASH pause FLASH pause FLASH FLASH pause FLASH
11 Supply voltage
18 Rpm signal
24 Oxygen sensor
31 Knock sensor 1
32 Knock sensor 2
34 Hall signal
44 Air Pump
Too many codes in the ODBII standard - besides that, these days basic code readers are really cheap - I keep a small one in my door pocket.
Ah that makes sense, thanks! I had a CEL last year, turned out to just be a misfire, but I was wishing at the time that I could have checked it with the CEL light itself instead of driving to a shop to use a reader.
I had an intermittent check engine light that would come on and off every now and then. Replace the O2 sensor and cleared it right up. easy diy for about $100
Resurrecting a very old thread.
Thanks for the detailed instructions BobbyT. FWIW, I had to reverse steps 1 and 2 below in order to obtain a readout; i.e. I had to:
- Depress the accelerator pedal fully
- Turn on the ignition, but don't start the engine
- Wait for the CEL to begin flashing
- Ease off the accelerator pedal, and read the codes
11 Supply voltage
18 Rpm signal
24 Oxygen sensor
31 Knock sensor 1
32 Knock sensor 2
34 Hall signal
44 Air Pump
11 Supply voltage
18 Rpm signal
24 Oxygen sensor
31 Knock sensor 1
32 Knock sensor 2
34 Hall signal
44 Air Pump
