993 Spoiler Drive Rebuild
01-16-2015, 10:19 PM
I did this last year and bought sheathing from eBay. It appears like this info is too late for the OP, but it may help someone else. Heres the link.
https://rennlist.com/forums/993-foru...e-bearing.html
01-16-2015, 10:39 PM
Quote:
Originally Posted by
JDB1
If you can't see the top edge(approximately 1/2 ") of your spoiler when it is fully raised, you may want to check your limit switch adjustment.
All I can see in the rear view mirror is the basket handle...
03-18-2019, 07:01 PM
Has anyone else used different lube besides the Marine grade on the worm shaft and wheel? Same grease on the inner cable?
03-18-2019, 09:36 PM
SearedRennlist Member
73 911T
I use Phil Wood waterproof grease when I rebuild these gearboxes.
Andreas
03-19-2019, 02:10 PM
AOW162435
Andreas
Andreas,
Any chance of you posting a link to your DIY?
03-19-2019, 02:21 PM
nine9six
Andreas,
It's all
here . I no longer use epoxy, but rather the Loctite 495 referenced in the thread.
Andreas
03-20-2019, 05:24 PM
Hello, did you use a very thin bead of ShoeGoo? Do you think it would hold up in a hot environment?
03-20-2019, 08:07 PM
03-20-2019, 10:26 PM
73 911T
I use LocTite 495.
Andreas
