Harbor Freight Lift on Sale
#46
I have an Atlas TDMR6 lift too. It has been a great lift for use with my Porsche. However I am having trouble with my other Unibody Cars.
The problem with the lift is the lengths of the lift arms. They are only 19.25 in long. So when fully extended outward the span to the outside of the lift pads is 59 inches. My Honda Accord and my Subaru Legacy have their lifting points 58 inches apart. They are also 60-61 inches apart between front and back. This requires that the arms be angled apart making the span less than 58 inches.
Therefore this lift is very limiting. There are a lot of Honda Accords out there.
I am in communication with Greg Smith to see if they have a solution but I am not getting any responses as of yet.
I have thought about using Bendpak arms which are longer. I am not sure what the diameter of the threaded retainment shaft is on the Bendpak arm or it's length. The Atlas uses a M20 Nut on the shaft. If they are compatible it may be an easy fix for a little more money.
Anybody with a Bendpak lift can verify I would be very appreciative.
In retrospect, I think the Atlas lift is a good lift but is very limiting. If you plan on working on other cars you may want to look elsewhere. If Greg Smith gets back to me I will update this with their resolution. Otherwise the Bendpak I believe would be a better lift.
Johnny
Johnny
#47
I lifted an '08 Accord, '14 corvette, 1967 corvette, and a '12 Tacoma w no trouble. The newer vette had to be positioned perfect to reach. Struck out w a Mercedes S class but that was to be expected. Interesting idea about the bendpak arms....
#48
If anybody has a Bendpak MD-6XP, measurements of the diameter and length of attachment shaft on the lift arm would be helpful in determining compatibility.
Johnny
#49
Johnny it's been a season since I lifted the accord. I'm pretty sure it worked from both directions on the lift. I recall that on the rear end I stacked two hockey pucks under the accords "frame" members where it bumped up, to get it level. I wasn't on the factory lifting points themselves though, I used the subframe.
#51
The dimensions marked by letters A-F in a box in the attached picture would be the dimensions that would be helpful to me.
I appreciate your time an effort to my cause.
Thank you,
Johnny
#52
HM993
Quote:
Originally Posted by eichlerman View Post
A scissor lift is on my wish list. I have been waiting for the right sale or opportunity like another group buy. I have read the past posts and remember a neutral to positive view of the HF lift. The HF lift is now on sale - save $300, plus I have a 20% off coupon. Is the HF lift worth $1200 compared to other options? I only have 46 inches ceiling height available so I expect a scissor lift is my only option. Any comments on long term support of scissor lifts? Are spare parts available? Is it better to buy a more reputable brand? I expect most of the frames for all brands are built in China but I do avoid HF electric tools unless they are for a one time use. And of course we do risk our lives and cars when we use a lift. Thanks for any guidance.
Just my opinion, but I wouldn't skimp on a lift used to support 3500 pounds above my head. In my experience, HF products are exceedingly inferior and some, downright dangerous.
Cheers
Joe
Are you the one that usually chimes in about the exploding air bag metal logo, the $100 helmet for the $100 head, the mini jump start battery that cannot work and now the this lift?
Thanks for keeping us all safe.
Cheers
Joe
#53
#54
I am doing this analysis for my own piece of mind but obviously can not guarantee it to the rest of the community. This modification will be at the owners risk.
Johnny
#56
Now to run the numbers then find out how much for replacement parts if all works out.
Johnny
#57
EMBPilot and others,
A consideration for those who need to precisely place the car, place all 4 wheels on rolling wheel cradles. This would allow you to easily fine tune the placement of the car prior to lifting. I believe a pair is ~$80.
#58
I have determined that the Bendpak lift arms and accompanying pads would fit the Atlas Lift. Taking account the longer arms there is a 24% increase in torsional loads so I have decreased the rating of the lift to 4500 lbs which would work fine in my situation.
My biggest gripe at this point is that Bendpak parts are priced like Porsche parts. The Lift Arm and Pad is over $100 each. This adds $400-450 to the price of my lift.
I am giving Atlas (Greg Smith) a chance to explain how I can use my lift to lift my two cars using factory authorized lift points before springing for other parts.
In retrospect, in my opinion and for my use, the Bendpak would have been a better lift for me. In the end it would most likely have been cheaper and with less headaches.
It's an ongoing process. I hope to have a resolution soon.
Johnny
#59
wow, good work johnny.
this is a bummer, i thought the bendpak and the Atlas more similar than Bendpak having longer more convenient arms. i would be ok with the reduced capacity and added room on the arms but the price is frustrating. i wish had caught that before buying that the arms were that much larger.
while i understand your reasons for not wanting to do it, i had no ill effects when lifting the accord from the subframe. the larger arms would be a huge help with the Corvette though as sometimes getting it precisely right takes longer than changing its oil.
well thought out investigative work here...
