Klasse - I'm doing it wrong!!!
Just been over to Autopia, apparently the preferred Klasse method is:
Wash Car
Apply AIO- wait 10 minute.
Apply AIO again - wait 10 minutes.
Wipe off with MF towel.
Apply SG and leave for at least 20 minutes.
Come back and wipe off with another MF towel using
either Meguiars QD or distilled water spray to help with the
removal.
voila!
wait at least 24 hours between coats of SG.
I'll be doing this this weekend...pics will follow if anyones interested...
and yes - I'll be doing my wheels too!
Wash Car
removal.
voila!
A wax job only protects whatever the condition of the finish.
If you haven't already, you may want to expand the "wash car" portion to:
a) Dawn wash ( to remove all old wax )
b) Clay entire car ( using claymagic and lots of QD spray )
c) Dawn wash to remove any clay/qd residue
You'll be amazed how smooth the paint is after the clay. It also makes the AIO go on a lot easier when the surface is nice and smooth.
Additionally, if you have any swirl marks, it would be a good time to remove them before you AIO the car. I've used the PC with great success. You can also use it to apply the AIO, whcih makes it a lot faster and give better coverage.
My first time claying wasn't as bad as I expected. I highly recommend this extra step if you're going all-out. Just follow the instructions provided with the clay bar. I accidentally skipped step (c) above but there doesn't seem to be any major impact so in the future, I'll probably skip (c) anyway. Btw, I was using the Zaino products (claybar, wash, polish, etc.)
Cheers Jeff,
Random Orbital PC's aren't widely available over here (in fact a mate of mine bought his while on holiday in Miami last year) and I'm a bit scared to put one against the paintwork of my car (nightmare scenario of taking the paint right off springs to mind!!).
But yes - I will most likely wash with Dawn-equivalent and then hd-cleanse (as I dont have any clay!!) and then wash again before moving 993 into the garage for the Klasse...
cheers
cheers
Has anyone had any experience with NuFinish? They have this one product which adds a silicone(?) coating over which lasts for 1-2 years. So if any dirt gets on, you can just take a towel and wipe off. The problem is, if you put it on and the car is dirty, the dirt will be there for 1-2 years also.
I think the instructions that come with their kit say to do a small section at a time (or was that the instructions on the bottle?). So that tells me that it really doesn't matter how you do it...
Remember that each application of AIO removes any previous coats of SG or AIO. Thus, I there's little reason to apply AIO twice unless maybe the paint is in pretty bad shape.
Originally posted by Surj-993C2S
Cheers Jeff,
Cheers Jeff,
If you need somebody here to order a PC for you, just let me know. I can forward the package to you overseas if you want.
As for the slickness factor most sealants provide this same feeling. As for dirt on your finish being “sealed” in, you should not apply any type of wax or sealant to a dirty surface. That being said most sealants will not bond with the surface properly if the surface is dirty or contains oils or fillers. Zaino is very particular about this. Klasse uses AIO to prep everything prior to the application of the SG. Nu Finish is similar to AIO in that it contains cleaners to remove anything that causes problems with bonding.
King of Cool
Trust me, I've tried to paint cars & helmets w/ silicone wax on it, it ain't easy to get it 100% off and paints don't like silicone...
Re: Nu Finish
Good product. Well rated by Consumer Reports for years, primarily due to ease of use. I have used it regularly on my drivers for over 10 years. It has a small amount of cleaner / abrasive in it so you do not tend to scratch the paint. It's easy enough to use that I wax my Pewter GMC 4 times a year to keep it looking strak. You can go much longer if you are not that particular. It does protect the paint well. You will want to remove the Nu Finish from your trim so as not to stain it.
That said I just used the Zymol cleaner/wax on my black 993 yesterday. Way more labor intensive but it really shines up. Costco has a Zymol wax and liquid finish kit for about $10 if you're interested.
Robin
Robin
Jeff - thanks again for the kind offer but I should probably spend my meagre funds on the car rather than ancilliary items such as PCs (for now ) - my wife would never understand that one!!
cheers
cheers
Normally what I do is this. Get up and use PPS with warm H2O. Rinse thoroughly and dry. Then I use the CS with my hands in order to remove DB and TS's. Wipe off with SCC and repeat if necesssary. I wouldn't use clay more than a couple of times a year, but after this I get the RVW and apply again with hands. At this point it is nice to GH the whole car with JHT and CBF. NB, CBF should be used ASAP after JHT. Get the SCC again and wipe down using NC movements. Repeat if necessary. HTH.
Wow...missed most of those TLA's myself.
Couple of points from my experience and reflecting only my opinion.
Zymol supposed to be the shti, but it is expensive and REALLY not durable. They share their brand name now with TurtleWax...the stuff at Costco is fancy TurtleWax, not Zymol.
Polymers such as Zaino are not as deep as Carnauba, but last probably 10 times as long, AND won't melt...yes, melt. If you have a dark car in the direct sun, it can often get hot enough to literally melt the wax...so much for the effort & $$.
I find that layering the Zaino does give some depth, but not as much as Carnauba. However, for me personally I like the ease of application and knowing I can layer and such. It also, in my opinion, provides more protection...stuff is easier to get off the car, incl. small scratches, with Zaino on the car.
Just my $.02.
Just my $.02.
