993 vague steering
RS tie rods really helped. Of course the standards were 18 years old so the rubber has had it's best time but the feeling is way sharper and now feels like a sportscar!
When orientating myself 5 years ago I tried some 964's and 993's. The front of 964's is gorgeous but the driving experience not that exciting. Steering was sharp but did not challenge the driver to play a little where the 993 is more easy to play with like drifting. What struck me more was that the 964 has not that much grunt below 4500 rpm. Then I drove a low mileage 993 with varioram and short ratio gearbox (MJ 96) and this felt way more responsive also taken into account the 6 speed gearbox. I didn't want to go the route of upgrading the 964 engine so I opted for the 993 which sometimes felt to much GT. Now with the revised/updated suspension in combination with the varioram engine, short ration gearbox, 18 inch hollow spokes and no weight increasing options it really wheels like a sportscar.
The steering on my 964 is super dead and loose on center. I can lightly move it from side-to-side while driving with no actual movement of the car. Compare my wife's 3 series, it totally sucks.
Everything is new/refreshed/poly/good working order (including rubber coupler in steering column)/caster is maxed/camber is -1.8/tires are 225 BFG Rivals, etc. Even when the tires are in the air, light movement on center translates to no movement of the steering. I suspect I have a loose/lazy rack.
RL Technical Advisor
Anther data point,...
We are finding more and more degraded steering rack bushings, allowing the rack to move laterally with steering input. Now we replace them with a harder product that improves steering response.
thanks
rob
Regards, Frank
