Help needed (to spend some money) for a '96 C2 tip
#46
This is an awesome Ross, as I'm sure you know.
If youre interested, use your Tip wheel controls to control your stereo. I've wished I bought a Tip wheel to try this ever since I upgraded to a 3 spoke 996 wheel. I think user "Spyder_man"(?) wrote up a tutorial on using Tip controls for his stereo. Could be a different user, hard to keep track of in my head.
http://www.pcarworkshop.com/index.ph...Steering_Wheel
#47
Hi Mark. Absolutely agree. I considered sourcing a manual ECU, but in the end had Juuso build me an ECU based on the MS3 processor as per this thread So I guess I'm going to find out what happens when we transplant in the replacement ECU and attempt to fire it up... It won't care about manual/tip, so in theory should just work.
If at all, disable the connector that lights up the gear display on tip style speedo
Keep us up to date on your project 👍👍
Regards Mark
#48
Ross
I used All Ports International Logistics (HK) LTD. The garage guys I used in HK recommended them and I had no problems with the process. This was back in 2008. They have a web site, and are located in Kwai Chung. http://www.allportsinternational.com.au/
I'm trying to remember the process as it was 7 years ago. I had to pay a free on the HK side. Ocean freight was HKD14,400. HK port charge + loading + docs + export clearance was $HKD5,650. Then minor things like marine insurance, pickup charge, and warehouse handling. All up HKD21,500.
I simply drove the car to the Kwai Chung docks where they where located and watched them load it into the container and then tie the car down so it would not move. I also put some bags and boxes of personal stuff in there as there was space. You want to make sure they tie it down as you don't want that nice paint job to be damaged. I also left A4 printed notes in the car for whoever was going to inspect it. I let them know where the battery shut off switch was, how to open the engine, trunk, etc. I wanted to avoid any damage that could happen.
I remember they asked about aircon refrigerant in the forms - it was R134A.
Leave your HK license plate on. Take it off when you get your new Aus plate.
There are a lot of forms to sign and fill in. But as long as you have all your documentation on hand it was just time consuming.
#49
Then one day the Perth office calls me in Aus and tells me the car has arrived and can be picked up after a few days. In that time they send me the bill for the Aus side of things. Total charges where AUD$7,818.34. So all up for freight, and taxes, the car cost me about AUD$12k to get back to Aus.
Then on the day I went to pick up the car I went to the driving license centre to get a 3 day temp license so I can drive the car home and then to the pits.
Make sure your airbags are working. Know that once you lock the door it takes 20 seconds for the immobilizer to activate and work. Know that the rear seat hooks are up on the parcel shelf - you may need to take the rear shelf off and physically show them. Aus and NZ delivered cars had these little tabs on the face of the rear shelf that could be removed to reveal the anchor points. For some reasons my car did not have them - so I figure all HK delivered cars won't have them. The other thing they looked for was the engine serial no. You have to know where to look and they probably don't check many 993's so they will have no idea.
#50
Ross
#51
Latest updates
So it's been a while... car is unfortunately still in HK, but some progress has been made and I'm hopeful things will now start to ramp up and I'll have it in a container headed to Australia soon.
I believe the mechanical work is all completed and I now have a manual 993.
They then started to repair the previously crappy paint job in preparation to respray the entire car.
And to remove the headlight washers.
Unfortunately, while I knew that the windscreen likely had some rust after spending 18 years in the Hong Kong rain and humidity, it was a little worse than I had hoped.
So the repairs begin.
That's where things are at present. Hopefully paint will go on this week and they can start to get it back together soon.
#54
I decided a while ago not to make this into a "replica" of anything. Cosmetically, it will end up with a turbo front end and Tramont Cup wheels - not because I'm trying to recreate something, purely as I prefer the look. This will be a daily driver which I intend to keep for many years.
#56
Ready to ship...
Looking a lot better than my last updates...
Comments from the workshop are that the RS gearbox + LWF + Juuso's ECU have transformed the car and it feels much more powerful...
Looking forward to getting it back to Sydney...
#57
Shipping...
Getting closer now... The car loads onto the ship on the 28th and is due to dock in Sydney around mid-June.
In the interim all I can do is start to hord other bits and pieces while I wait...
#59
LED lights were from https://www.superbrightleds.com/more...edge-base/228/
And the holders were from http://www.crazyleds.co.uk/509T-twist-lock-holder..html
This recommendation came from the following thread: https://rennlist.com/forums/993-foru...-gauges-9.html
I obviously don't yet know if they are truely plug and play till I see the car again...
#60
Active HiFi based on the Pioneer DEX-P99RS DSP
OP -
You're going to luv the active HiFi enhancement. .... went with this Tour de Force P99RS of a head unit several years ago. Dam, its a well thought out car audio kit. Excellence in every way ...
With the addition of a 3rd Party module (I forget the co name) your Tiptronic steering wheel controls will operate the P99RS.
Nice project !
Nice project !
