Heat exchanger hose alternative
op thanks for putting up the thread.
jhg41977 mine look a little worn I'll take some of your hands if you have it - I'd like enough to do both sides (of both flappers) would that be 4 pieces?
I have never had to remove the heater flap/valve assembly to change the oil and filters. I work through the RR wheel well detach one side of the hose leading towards the front of the car from the valve assembly and push it out of the way. I also do not detach the other hard pipe that so many say needs to be removed.
cheers
Mike
Pm me your address and the length you need. I'll send them out tonight and then send you a total. PayPal is easiest for me. If you don't like it or don't have an account let me know and we can do something else
https://www.forgemotorsport.com/70mm...duct--540.html
apparently they have 70mm that looks like OE ...
Edit: I have this exact stuff, same size, sitting in my basement, so I'll mail you a piece for free if you want. I really don't think it would be durable enough though.
thank you @TheOtherEric , but I realized what you posted a few moments after I posted myself (DOH)
I ordered something similar to @OverBoosted28
best,
Paul
best,
Paul
