Suspension
Suspension
Hi
I have some Eibach lowered springs which I eventually will put onto my '96 C2. (52000 Miles) They apparently will lower the car approx 1.00 to 1.5 ''. Much better effect.
The question is has anyone done this on standard shocks or is it always a shock change. Can the lowered springs be helped by stiffer sway bars/Anti Roll bars.
Not sure what to do as at present there is no reason apart from asthetics to change all the shocks, ie no leaks etc. Handling on the soft side but standard.
Any thoughts.
Steve
Any thoughts.
Steve
Most people here will tell you to replace the dampers no matter the milage as 20 year old shocks have likely gone bad. Furthermore, the technology within has advanced significantly in terms of performance and durability.
However, as you have asked, the springs you possess can be used with your current dampers. For 993 specific suspensions, pretty much every spring that is sold separately from a damper and every damper sold separate from a spring will have intercompatibility with themselves and any stock setup.
I am not sure what you mean by "helping" your springs with sway bars. Changing the sways is not necessary and does not necessarily
make anything "better" only more suited for your desired ride.
Changing the shocks will result in no change to asthetics. It will improve handling and confidence so you will "look" better going round corners, but the car will appear exactly the same in a straight line or standing still.
Sorry I meant to say apart from aesthetics no need to use the springs because there does not appear to be any issues from the shocks.
I do take you're point about 20 yrs etc . We're the originals Monroe, oil or gas.
I think I'll keep an eye out for some Koni or Bilsteins.
What are m030s that I keep reading about.
Steve
Steve
Steve
Steve
That's what I thought might happen.
Were there m030 shocks under the same banner.?
What I was thinking of doing was changing sway bars , keeping standard shocks (if not damaged) fitting the eibach lowered springs so as to hopefully achieve a compromise.
Remember I'm in the U.K. with smaller windy roads lots of traffic, roads with camber and the need for quick overtaking so need the handling.
Thanks Steve
Thanks Steve
^This. The Monroe OEM shocks generally last about 20K miles. Koni Sport, Koni FSD and Bilsteins are all relatively affordable modern options and they will last a long time. You're gonna have to do it sooner or later.....
The Monroe's are garbage. You will get a huge improvement from better dampers. If you aren't tracking the car I would skip the sway bar change and put the money into better dampers. You will be amazed at the improvement.
I just nailed a new set of the Koni FSD's on eBay for $857 shipped - $70 less than TireRack. Also upgrading to the RoW M030 springs.
1 Post
When I bought my car 5 years ago it had Eibach springs. I would never intentionally use these springs. If I am to assume that you are not wanting to spend a great deal, using the OEM M033 springs that should have come with the car originally with Bilstein HDs would be the far better choice. Eibachs produce a very weird looking lowered stance on the car with the rear appearing to look lower than the front though not actually so in reality by measurement.
I had Eibach springs on mine with Bilstein shocks. The ride was very stiff and not enjoyable. I have just upgraded with PSS10s and they are great. The ride is awesome and handling great. Got my PSS10s from FD Motorsports.
