More A/C Weirdness
More A/C Weirdness
Recently the A/C unit ('96 993 C2 w/52,000 mi) has developed a wheezing noise under acceleration. When under constant throttle pressure I get cold air but if I accelerate at all, the vents stop emitting any air, or emit low pressure warm air. Then once I ease up, normal cold air again. Is this a CCU, servo, mixing flap, compressor or what problem? Thanks for any input you may have.
I agree on the note of a vacuum leak. This makes the resirc flap to become saggy under acceleration. I also had the leak in the reverse air intake changeover valve. This is described in the above mentioned HVAC DIY.
Cheers,
Tore
Cheers,
Tore
My weird case:
My AC does not blow air in fan settings 1 and 2. It blows well in 3 and 4. Last year, it was fine at 2 while 1 setting was not blowing air.
Is my rear fan going out which is shutting down air flow?
Evap replaced two years ago.
