So I backed out of my driveway this morning and scraped the exhaust tip. Thought it was kind of weird as I normally never scrape. Went to put gas in it and noticed the drivers side exhaust was hanging about 3 inches lower than the passenger side.
The motor mounts were replaced last year with new mounts purchased from Pelican. Could it be that the mount is bad already? I didn't see any fluid on the ground or under the car. Confused!
Any ideas?
Without seeing it for myself, all I can offer is an educated guess, but it does look like a failed engine mount to me (unless the current one is loose).
Did you use genuine Porsche factory ones or OEM equivalents?
Ok well just went outside to take another look. The motor mount is torn in half. The rubber insert ripped right out of the metal mount. I can stick my whole hand between those two sections! Now my next question is whether its safe to drive it to get it fixed?
Ok well just went outside to take another look. The motor mount is torn in half. The rubber insert ripped right out of the metal mount. I can stick my whole hand between those to sections!
Wow! Can you post a photo?
Originally Posted by ginch
I used an OEM equivalent ( Corteco ) that I bought from Pelican.
Did they come in a Rein or a Corteco box? If they came in a Rein box, you may want to consider contacting THESE GUYS...
I'll post a pic once I remove them. Now the next question is should I go with stock OEM or try RS mounts? Tried black top wevos before and hated them. With my windows up they sounded like the motor was knocking for some reason. I don't believe the RS mounts are as hard though so they might be better for me.
If you're sensitive to any added cabin noise, just go with OE/OEM. The RS gave me a bit more cabin noise, not massively different, but noticeable.
