Clutch Stop?
Does anybody know of a Clutch Stop for our 993s?
A friend of mine with a e46 M3 mentioned that he installed a clutch stop so he has less "wasted" travel on the clutch. My clutch engages/dis-engages about half way through the pedal so I'd like to stop the pedal from moving much past that. This would making driving and shifting both easier and faster.
Is there a part made for the 993 to do this or has anybody fashioned a DIY solution?
Thanks in advance, and sorry if this has been covered before. I tired searching but didn't come up with anything.
Interested to hear about this. Not really an issue for me with my gigantically long legs, but my wife actually has to have the seat quite far forward to get her leg to extend to full clutch pedal travel.
I guess the advantage to such a device or feature is that you have some positive indication you've pushed the clutch in enough to fully disengage during a quick shift.
Worn clutch?
When i drove 993 with new clutch the operation was at the very low end of the pedal travel (i.e. as soon as you let the pedal go, the clutch would start engaging). My clutch is old and engages at very high point and requires a harder push.
Newer clutch makes shifting quicker and easier, but I'm putting off my clutch replacement to 90k service.
Worn clutch?
Sure, I can just not push the pedal all the way but like that you have no feedback as to it being fully disengaged. The clutch stop would create the "end-point" for the travel of the clutch. This would then be adjustable so that I can set it at the correct point. The shorter pedal travel would make it a lot easier to drive around town as well as make shifting faster when going for more spirited drives.
Its a very simple device, I feel like I could just go to home depot and come up with something but I wanted to see if there was anything made for our cars that would fit without much thought/modification.
Here's a picture from a quick google search:
![](http://d5otzd52uv6zz.cloudfront.net/169dc0b4-6ef1-460e-a645-11f29194c5aa-800.jpg)
Well, I ended up answering my own question by tracing that photo to this post:
http://www.6speedonline.com/forums/996-turbo-gt2/182676-new-adjustable-clutch-stop-rss.html
You'll notice that the original post in that thread mentions that it wouldn't work on a OEM clutch, reason being that there is a switch somewhere behind the pedal that only engages when it is fully depressed. This switch would prevent the engine from turning unless the clutch was fully dis-engaged. Apparently this can be bypassed by connected the two wires on that switch.
That RSS clutch-stop looks like a real nice piece, but rather pricey for the job its doing. I'm going to give home depot a shot and see if I can rig something up. Will post here for anyone that is interested!
There is a clutch stop on the driver's footboard, and it does have some adjustment. You can see it if you remove the carpet. I don't think it is intended for the use you describe, however.
In my experience, the transmission on the 993 isn't one that shifts as quickly as say, a Miata or Honda. It seems to shift easier if one makes a little pause at neutral. Quick shifts may lead to an early transmission rebuild...
Doing a google search, as you did, shows mostly BMW mods. Some of these look like replacing or adjusting an existing clutch stop, some look like installing something into the floor, and others are attachments to the pedal itself.
Technical Guru
