CAN SOMEONE IDENTIFY 993 SWAY BAR
Just trying to establish a few Parets in Suspension for Set Up purposes.
THAS A SMALL DAB OF WHITE PAINT - IS THIS 22MM SWAY BAR ?
tHANKS FOR YOUR ASSISTANCE.
TJ
TJ
What car is it on? Carrera? Turbo? Does the air intake on the engine have a chrome horn - an indication of a m030 suspension. Do you know the car's option codes from the sticker under the hood?
Andy
Andy
Hi Andy
Car has Sport Chassis
and 159 Chrome Ring on the Air Box
Yes it indiucates M030 But was hoping to avoid Jacking the Car.
Figured somebody here will recognize the Dab of Paint on the Sway.
97 Carrera Coupe
TJ
97 Carrera Coupe
TJ
Huh? How do you correlate the Motorsound option, of which the air filter cover with chrome ring is part of, with M030 suspension? This is like saying having the HiFi option is an indicator of having an LSD.
for reference the yellow paint marked swey is 17mm (rear)
Last edited by lopro; 05-27-2014 at 09:46 PM. Reason: forgot to mention which front or rear. not sure if that makes any differenace
If u read the earlier posts u would know where the comments and reply came from.
I do appreciate the Positive Answers you share.
I am certain you have a Positive effect within your sphere of influence.
Here I was trying to avoid Jacking up my car and Measuring.
There are so many knowlegeable people here I figured someone would happily share their knowledge.
Isn't This a Great Place!!
'Thank You for your contribution and answer to my query.
TJ
TJ
Oh Really - Now that is interesting.
I wondered why my Rear Sway has Light Blue Paint and the Front is white Paint.
Light Blue from my reading indicates M030.
The white paint on the Front Sway threw me off.
My Car had the Sport Chassis installed by the Dealer when New.
The Parts were shipped from Porsche to the Dealer. I have the Documentation.
I was hoping someone here may provide some insights and save me the aggro of jacking up the car.
On my first DE the instructor said the car was Pushing - now I know that is a different question but knowing which parts are on the car is a start to finding answers.
Thanks again for sharing! Appreciated.
I gather it is time to jack up the car and start measuring.
Regards;
TJ
Regards;
TJ
OMG, I think I'm gonna die from laughter! ![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
TJ,
A flashlight and cheapie China made, 6" digital venier caliper set to mm, will give you your answer. You might be able to get a caliper on the bar without jacking up the car, but then again its only one wheel you have to lift...
All toolboxes should contain a digital venier caliper. On sale, they are $10 US; ordinarially $19 at Harbor Freight tools.
TJ,
It may not be the easiest thing to do, but I was able to measure mine without a lift, just laying on the ground and sticking a ruler with mm markings on it up against the bar. The rear is doable, probably not the front.
Not as accurate as a caliper, but the difference between the stock rear 17mm and M030 20mm is pretty significant, so the measurement does not need to be super accurate to discriminate between the two.
FWIW I went with the RoW Turbo Rear bar, which is 21mm, and a very nice setup. I do not think mine has a white paint stripe on it. I bought it from Sunset.
TJ,
TJ,
please do not die....Don't want anyone to charge me with manslaughter.
my original comment was not intended as a joke or an insult, that is how I actually figured out which bar I used to have on the rear. I was concerned because the original owner installed M030 springs, but I was unsure if the bars were also changed.
