Another front license plate install......
Recently I have been pulled over several times now by the same local police officer and each time he was kind enough to give me a warning. I am thinking I may be running out of warnings......
For years now I have been thinking what would be the best option and even though I like the tow hook design it still takes away from the clean look on the nose.
The plate needs to be somewhat hidden so the only option really is the way Mike J. and Baron went.
I am not sure on the details how they did their install. And I believe they had to trim the plate which I was hoping I didn't have to do. So I removed the grill and noticed by cutting out the center section the plate would fit perfectly behind it.
All that was required to do was cutting some narrow slits on the back side for zapstraps and bob is your uncle!
So below are some pictures of what I did and re-installing the grill with the full plate mounted went without much trouble.
I'd like to play with a few options to conceal the plate and will share that later.
Anyways just sharing.......
![](https://farm6.staticflickr.com/5460/14130395881_7713b5689e_b.jpg)
![](https://farm8.staticflickr.com/7332/14130397061_60c57cfac4_b.jpg)
![](https://farm8.staticflickr.com/7398/13947107918_52e1e0543f_c.jpg)
Nice solution, any pictures from further out?
I just got 2 tickets this month for this. I'm switching to a classic car insurance this month and will try to fight it in court. I wonder if cars that are considered "classic" are required to have a front plate.
FYI: I'm in NY.
FYI: I'm in NY.
Looks like a nice solution to your situation. When I moved to Pennsylvania and registered my cars the Dept. of Motor Vehicles gave me only 1 Plate. I asked her why only 1 plate, to which she responded " In Pennsylvania the police only chase you from behind."
Next you will be told your plate is not fully visible!!!
Best Jack
Best Jack
that is a very clean look for those with a turbo nose. I didn't cutout any section of the grill, just trimmed the tabs on the bumpercover in that center section. The plate is sandwhiched between the black grill, and bumpercover.
Many States have laws against any plate obstruction, that included even frames around them. New York State is one such wonderful place. Chances are pretty good that if they wanna write you a ticket for a "partially obscured" plate, there's no talking your way out of it anyway.
At least here you cant have anything obscuring any portion of the plate...ridiculous
http://www.foxnews.com/politics/2014...cmp=latestnews
The vinyl solution here in BC seems to generate tickets.
I guess the advantage of Han's solution is that you do not cut the plate - which you can get a ticket for here in BC. , but the disadvantage is the grill needs to be cut as well as removed. Great alternative!
Cheers,
Mike
Cheers,
Mike
that is a very clean look for those with a turbo nose. I didn't cutout any section of the grill, just trimmed the tabs on the bumpercover in that center section. The plate is sandwhiched between the black grill, and bumper cover.
I will be ordering Many States have laws against any plate obstruction, that included even frames around them. New York State is one such wonderful place. Chances are pretty good that if they wanna write you a ticket for a "partially obscured" plate, there's no talking your way out of it anyway.
Obstruction I hope is not an issue here as plate surrounds would do the same and are allowed here.
Cheers,
Mike
Cheers,
Mike
Removal of grill went easier then I expected. Re-installing with the plate attached went back in without any damage to the paint, plate or grill. If I wanted to I could actually switch back and forth between grills. But if my idea of an alternate option works I will share that here.
I will be ordering a replacement grill to put on the shelf.......
