993 Forum 1995-1998
Cracked brake caliper
Old 02-22-2014, 01:40 PM
SC2993
SC2993's Avatar
Default Cracked brake caliper
Coming home from a short drive I put the brakes on and the pedal went all the way to the floor. Luckily I was doing about 7-10 mph and in my neighborhood, the weather was about 28 degrees. Pulled the car into the driveway and noticed brake fluid under the drivers side front wheel. My car just turned 20 in January and thought that maybe the brake line had busted. Knowing that I could not drive the car I had it taken to RAC to have them look at the issue. Once they got into it they found this! Not sure how this happened on a 20 year old car with no previous brake issues, the guys at RAC are stumped too. Glad that I was not travelling fast when this happened, most likely it could have been much worse.
Old 02-22-2014, 02:35 PM
TMc993
TMc993's Avatar
Wow! I've been driving and working on cars with disc brakes for well over 40 years and have never seen anything like this on a non-competition car. You're very lucky it happened when/where it did.
Old 02-22-2014, 06:40 PM
ilko
Agent Orange
ilko's Avatar
This is crazy! Never seen anything remotely similar. You may want to report it to Porsche and NHTSA.
Old 02-22-2014, 07:34 PM
Vandit
Vandit's Avatar
Wow, WTF! That's a crazy failure. Was this on the face of the caliper or the backside where the line fitting goes into? Did you recover the broken piece or was that lost? What does the face of the crack/break look like? Any signs of corrosion, like something that started small and then took the whole caliper?
Old 02-22-2014, 09:18 PM
Steve Weiner-Rennsport Systems
RL Technical Advisor
Steve Weiner-Rennsport Systems's Avatar
Thats a first for me, too.
The forensics REALLY need to be done here to prevent other people from such failures as it may have been a faulty casting or some type of impact damage.
This is one I'd talk with Brembo about.
Old 02-22-2014, 09:54 PM
P-daddy
P-daddy's Avatar
Crap! That looks like the inboard side.
Old 02-23-2014, 12:21 AM
Rick-A-Shay
Rick-A-Shay's Avatar
No expert but, it looks like a clean break! Usually if a casting develops a crack, dirt will enter the crack and cause some discoloration. When the actual separation finally occurs, you can see the clean metal in the break vs. the dark area where the crack was. Just saying…… Still, rather scary!
Old 02-23-2014, 01:11 AM
L23FPorsche
L23FPorsche's Avatar
Just a thought. If the through bolts on one side of the caliper were missing/fractured, the pistons could potentially do this.
Old 02-23-2014, 09:21 AM
SC2993
SC2993's Avatar
The crack is on the inboard side of the caliper, we looked for any sign of corrosion and did not find any indicating that there was a previous break. The caliper will be sent back to determine what happened, maybe a bad casting. The bolts that were removed were in good shape. Strange that this happened after so many years on the car with no other symptoms.
Old 02-23-2014, 11:03 AM
996scott
996scott's Avatar
Wow, that in amazing. can't even imagine how that happens.
Old 02-23-2014, 08:01 PM
pp000830
pp000830's Avatar
Received 1,458 Likes on 1,028 Posts
My understanding is that if the casting had impact damage one can look at the texture of the crack and follow it to the initial propagation point and then look for and impact or scratch irregularity on the exterior surface of the part adjacent to the crack.
Old 02-23-2014, 08:12 PM
jhg41977
jhg41977's Avatar
Wow, you are very lucky it haplened at low speed with nobody in your way!
Old 03-02-2014, 11:17 PM
3healey
3healey's Avatar
Having suffered a total brake system failure at speed (see my avatar), this scares the crap out of me. Any news on what caused this?
Quick Reply: Cracked brake caliper
