CCU problem...
I've looked at my spare CCU and the circuit is different than yours - in that area are 2 smt transistors and only 3 smt resistors. It's the two button snow flake with version B10003/7 display pcb.
Anyway, if your problem is associated with the backlighting circuit, realize that each button should light up when pushed in, and the back light bulbs behind the fan speed and temp ***** light up when your headlights are on.
Did you happen to verify the correct bulbs is in the display?
ToreB has been amazing in all of this and I couldn't have gotten to this point without his help whether through emails and through his amazingly precise documentation. I love his products and the dude has been invaluable to me.
So close to the end of the tunnel, just have to press a couple of buttons and that hopefully will be that.
G
Tore and all,
Regarding the CCU and the motorized servo, what would happen if a damperwas stuck half closed, or was gummed up and barely moved, and the CCU was asking it to fully close? Would something in the CCU overheat and pop, or the traces/whiskers in the servo burn up? Could a stuck/difficult to move damper flap cause the burnt trace in the servo boards?
Follow-up - if so, should we pop out the dampers and clean them?
Thanks!
Thanks!
The CCU supervise the movement and stops it if the servo does not respond to applied motor signals. However, we sometimes see burnt CCU servo outputs, but this is probably mainly caused by excessive motor current due to wear. All details on this can be seen in chapter Electric flap servos here.
Cheers,
Tore
Cheers,
Tore
"The CCU supervise the movement and stops it if the servo does not respond to applied motor signals."
Actually the servo motor driver IC can be damaged even though the microcontroller
monitors the servo motor's position. Each IC functions as a basic 'H-Bridge' circuit.
