993 Forum 1995-1998
Shift rod
Old 01-22-2014, 05:55 PM
OverBoosted28
OverBoosted28's Avatar
Default Shift rod
My latest home-grown project is a shift rod. Wow!!!! if none of you have installed the FDM "Golden Rod", do it now! I cannot believe the slop in the ridiculous diaphragm shift coupler. A couple of pics of the old rod with the coupler and what I intend on replacing it with. I'll try and load the video of how bad it is. Name:  shift coupler 1.jpg
Name:  shift coupler 2.jpg
Name:  shift coupler 3 .jpg
Name:  coupler u-joint comparison .jpg
Size:  150.0 KBI'll keep you posted.
Old 01-22-2014, 06:19 PM
chaoscreature
chaoscreature's Avatar
Tha'ts a hefty looking U-Joint!
You will need to machine a piece to fit snugly over the shifter rod that's sticking out of the transmisson and weld it to the U-joint then weld the U-joint to your cut shaft.
Be VERY careful aligning the u-joint when you weld it to the shaft, it's very sensitive to rotational mistakes and will throw the shifter handle to one side or the other.
I ended up adding a piece of threaded rod with a jam-nut to mine after welding, installing, cutting, welding, installing, cutting, welding, installing, crying!
Old 01-22-2014, 06:34 PM
OverBoosted28
I had already contemplated both of those points. I was going to center the shifter side of u-joint vertically so as to be in line with the actual shifter. The trans side of the u-joint will sit laterally. Did you buy a bushing to reduce the u-joint at the shift shaft/trans or mill one?
EMBPilot
EMBPilot's Avatar
I don't get it... Why not just buy the FDM GR u mention in ur OP??
Old 01-22-2014, 07:53 PM
OverBoosted28
$$$$$$$$. U-joint was $40 bucks and I can do it myself. Of course I would love to buy the rod already done, but can't justify the cost when I can make one myself. Like I said before some of us can't really afford these cars. When you have F'd up priorities you figure out ways to get things done.
Also wanted to tell those that can afford it to buy the FDM quality product because I believe ALL our cars would benefit from it. Hell, if you really want to throw money away find a real RS rod and buy that one :-)
Old 01-22-2014, 08:04 PM
EMBPilot
EMBPilot's Avatar
$$$$$$ = $200 ?
Old 01-22-2014, 08:27 PM
OverBoosted28
$240 may not be much to you but unfortunately I live paycheck to paycheck so.............
Old 01-22-2014, 10:02 PM
EMBPilot
EMBPilot's Avatar
You already spent $40. If u can copy the FDM GR for less than $200 from here then have at it. Having said that, this is one item in particular I would want no part of fabricating on my own... Good luck though! Keep us posted.
Old 01-23-2014, 10:29 AM
Garth S
Garth S's Avatar
I'm with the OP .... some of you guys just don't get it! It is not always the money - rather the satisfaction of a DIY that works far better that OE.
Re the cut & paste of a 'stout' universal to a stock shift rod, take a look at my mod back in '09 DIY RS clone.
Make up a simple jig as shown, and it will be dimensionally correct once welded.
The U-joint I had used which received all the disparaging remarks is exactly the same joint that every 993 driver clutches between his mitts when steering the car ..... ya'know, the one responsible for that fine steering feedback. Actually works quite well on a shift rod too ....
Old 01-23-2014, 10:36 AM
JB 911
JB 911's Avatar
That's one thing I enjoy about this board too - the diversity from the above DIY all the way to those who can do open checkbook 9Meister projects and everything inbetween - it's all good - keep it coming.
Old 01-23-2014, 10:52 AM
chaoscreature
Agreed with Garth, although money can be a very important factor! I was too cheap to buy a $40 u-joint so I made one... I was putting my wife through college at the time so I was broke and had WAY too much free time on weekends...
I didn't take any real pictures of this part, but it's my U-joint combination transmission mounting point. The body is 1" OD 304 stainless and the "yoke" is 1/2" stainless key stock.
Old 01-23-2014, 12:12 PM
OverBoosted28
I found a steel 3/4" X 5/8" sleeve/bushing that'll be perfect for the shift shaft mount side of the u-joint. Just like the rear control arms I fabbed up, I went overkill on it so I couldn't kick myself for under engineering it and having to fix it later. Thanks for the above encouragement. I can't stand it when people say "why don't you just have someone else do it". I know exactly whats in there when I do it myself and don't have to try and figure out what they did or didn't do. Also for the most part, I trust no one. :-)
Another note: I appreciate all of the great things that alot of these manufacturers have produced and would love to be able to buy all of them and then pay someone else to put it in. That won't happen. So those of you that can afford to do so, help out our sponsoring manufacturers and buy their products. Thanks
Old 01-23-2014, 12:54 PM
jason89i
jason89i's Avatar
Love the "home grown" approach. I too enjoy the hands on approach to owning. Here is a crummy pic of mine in the works. The shifter shaft was .634", so a 5/8"id u-joint can be utilized if it is opened up a small amount. The threaded setting pin goes completely through the shaft. I plan on using a longer bolt with a nylon locker on the other side as a back-out safety in lieu of lock-tight.
Do you have a c4/turbo? Looks different than mine. offset bushing for driveshaft clearance?
PS. Came across your previous post regarding adjustable rear links.... love it.
i can see how this would be very sensative to rotational positioning.
i cut my shifter rod down and slid in an intermediate piece. fits snugly inside the shift lever. this gives the ability of tacking after install to fine-tune x/y position of shift lever.
Old 01-23-2014, 01:07 PM
pp000830
pp000830's Avatar
Received 1,571 Likes on 1,108 Posts
I wonder if someone took the coupler out of a 80s vintage Carrera it could be adapted. It had a nylon bushing that isolated vibration but was rather stable. I also seem to remember it had some adjustability.
Old 01-23-2014, 02:32 PM
Kika
Kika's Avatar
I applaud those guys (and girls) that venture to create solutions/improvements on their own, at one point even the Golden Rod was an idea, that came to market.
I am thankful for those that innovate, and bring these enhancements to the rest of us. I do not have the tooling or skills to manufacture a shift rod on my own, but I am thankful that FDM did have the skills and the capability to deliver it to those of us that don't DIY.
Ditto with the tie rod pinning, and kudos for sharing it with the rest of us.
OP should not be slammed for sharing, that is what this forum is about.
An even CHEAPER solution was to remove the rubber bushing and replace with a bunch of washers. I think that is in the archives as well, not as elegant as a swivel joint, but probably even cheaper.
Quick Reply: Shift rod
