Parking on slope - bad effects?
I park in an apartment garage and the parking spot is on part that goes up to the next floor. The angle is small - a few degrees. Any bad effects from paking on an angle (side to side)? When drving car often I switch sides (pull in or back into the spot). Now the car is not driven much. Im thinking of making stands to go under lower side. Am I paranoid?
Thanks for confirmation. I thought I was, but figured if it's not driven for a month perhaps it should be on even surface... There is a new 991 parked next to me and obviously he is not concerned either.
actually, parking like this will cause wear on your car's gyroscopic bearings yury. That and the angle sensors. Make sure to flip the car upside down to reset these before driving.
RL Technical Advisor
You have nothing to worry about at all here.
Received 5,402 Likes
I'd be more concerned about level of battery charge after a month of sitting. Any electrical outlet nearby where you could plug in a Battery Tender? You could route the detachable plug lead through the closest drain plug in the "frunk".
