993 Forum 1995-1998
What new tools should I buy?
Old 11-11-2013, 06:46 PM
P-daddy
P-daddy's Avatar
Originally Posted by tcsracing1
a thick wallet and cell phone for your local indy....
Old 11-11-2013, 07:35 PM
pp000830
pp000830's Avatar
Received 1,536 Likes on 1,085 Posts
I forgot one very important item. An extra immobilizer key fob with a fresh battery stored in the trunk, just in case. Having to use it once will save you a tow charge and a lot of aggravation. I would also get the radio and ignition immobilizer codes from the dealer and fill out the attached form and put it in your owner's manual as you may need it some day.
File Type: pdf
Old 11-11-2013, 08:33 PM
FrenchToast
FrenchToast's Avatar
All of these should do the trick.
It's usually worth it to invest in quality tools from the start. Cheap ones break. Which can be annoying, but more importantly dangerous.
And never use any old piece of pipe laying around for an extension. Needs to be hardened, seamless, etc.
Torque wrench. Get a good one. A good one can outlast some cars and still remain accurate.
Take care,
Old 11-11-2013, 08:36 PM
XavierLaFlamme
XavierLaFlamme's Avatar
I would get the workshop manual cd-r on eBay for chesp and read as many DIYs as you can.
The brain is the greatest tool.
Michael
Old 11-11-2013, 08:43 PM
justin993
justin993's Avatar
Take care,
Never use a torque wrench without Bono safety goggles
Old 11-11-2013, 09:03 PM
Magdaddy
Magdaddy's Avatar
well, a more expensive suggestion than any other so far...but the one tool, that will make all others easier to use. The one tool that will simplify everything from oil changes, to detailing.
the scissor lift
worth every damn dollar
Old 11-11-2013, 11:22 PM
XavierLaFlamme
the scissor lift
I second that. And knowledge...
Michael
Old 11-12-2013, 06:43 AM
Age100
Age100's Avatar
Thanks for all the good advice....once again.
I have just ordered an air jack to make life a little easier when crawling around under the car. It lifts 4T to about a 100cm and should be gentle on the underbody I will try it out at the weekend and post some photos.
age
Old 11-12-2013, 09:20 AM
justin993
justin993's Avatar
A little off the OP's original question...
I believe Alex (IXLR8) had a really good list of tools/supplies to keep in the car along with the factory tool kit.
I forget where it was posted
Old 11-12-2013, 11:23 AM
boulderbobo
boulderbobo's Avatar
Originally Posted by Age100
Being new to 993 ownership i'm thinking i may need to invest in some particular tools so what tools can't you live without?
I have a reasonable tool kit but just ordered Irwin bolt grip set (used to remove damaged nuts/bolts), purchased with the assumption if I own a set I won't ever need them...
The car has spent 17yrs in the UK (now in Aus) so with all that salt exposure there are going to be some stuck...stuff.
Anyway keen to get your thoughts
The answer to your question depends on what you plan to do to your car. I found that you don't really need many specalty tools unless you plan to get inside the engine or transmission. Pick your project, read the DIY. Most DIYs provide a comprehensive list of tools necessary for the project.
Enjoy!
Bob-
Quick Reply: What new tools should I buy?
