993 Forum 1995-1998
Jack pads...are these too small?
Old 11-08-2013, 11:28 AM
JPS
JPS's Avatar
Default Jack pads...are these too small?
Tired of fumbling around under a car lowered to about RS spec, I decided to get some of the cool little locking jack pads. However, are these too small? Seems part of the point would be to spread out the load as well as a standard jack does, not concentrate it? Or am I missing the point.
Old 11-08-2013, 12:27 PM
nrubenstein
nrubenstein's Avatar
I've got a set oft hem and have been happy.
A lot of the value is not so much in spreading the load around a lot as not having jack/lift "pads" gouging your paintwork underneath.
Old 11-08-2013, 02:25 PM
IXLR8
IXLR8's Avatar
The ones I have of similar design are 2.5" in diameter by 1" thick. Small, bigger, no big deal.
If you are going to leave the car on them for a long while, place a layer of 6 mil plastic sheet (vapor barrier) between the car and them so that the undercoating does not stick to the pads.
Old 11-08-2013, 03:36 PM
Tim, near Boston
Tim, near Boston's Avatar
I have a set, they work OK.
Old 11-08-2013, 03:44 PM
Meatball964
Meatball964's Avatar
Funny, I just today shaved 2 hockey pucks I had laying around for the same reason. I use 2 Hessco jacks for the rear which line up nicely as is. I'll use these for the front regular v-shaped jack stands for stability & no under plastic contact. I'll post pics if anyone is interested. Cheapest mod I've ever done.
Old 11-08-2013, 05:37 PM
P-daddy
P-daddy's Avatar
Lets see 'em
Old 11-09-2013, 09:11 AM
KBell
KBell's Avatar
Second the Hockey pucks.
Used them for many years.
Old 11-09-2013, 09:38 AM
rlme36
rlme36's Avatar
for my use I've been toying around with making these fit. Available at every BMW on the planet
http://www.turnermotorsport.com/imag...11960752_1.jpg
they should fit with a little work I think. I happen to have some laying around from my other car. I snap them in and out for use on the lift so the lift pad doesn't grab the bodywork.
rob
Old 11-09-2013, 11:13 AM
x50type
x50type's Avatar
When i received mine, i thought there had been a mistake. They are ridiculously small in diameter, the load bearing surface is <1 square inch. I might put them under a model car but not my 993!
Old 11-09-2013, 11:25 AM
x50type
x50type's Avatar
Silver pad - toy.
Red pad - not a toy.
Old 11-09-2013, 12:22 PM
Paul902
Paul902's Avatar
^ Who makes the red one, and what is the overall diameter and thickness excluding the post?
Old 11-09-2013, 01:43 PM
x50type
x50type's Avatar
Paul902
OD is 4 1/8"
Thickness is 1.00"
Load surface is 2 1/2" diam
Post size 1.1/4 x 15/16" x 1/2" [the size of the jack point hole on the 993].
Subtract the 1 1/4" x 15/16" jack point hole area from the OD area minus the pin area of the toy and you have the load bearing surface of the toy............................pretty damn small!
Old 11-12-2013, 11:51 AM
Rod95C2
Rod95C2's Avatar
Default Jack Pad
I'd also like to know where you got the red one. Thanks.
Old 11-12-2013, 11:56 AM
Mike J
Mike J's Avatar
Hockey pucks ...
I like the cushioning, and they grip well. Perhaps not as positive as a lock as the ones with the tabs, but I usually need a puck on many of the 993 that come in - for the left front mount which is often bent or has a failed weld. When that happens, the metal pucks are useless.
Cheers,
Mike
Old 11-12-2013, 11:59 AM
IXLR8
IXLR8's Avatar
Actually, the 2.5 inch diameter that sits up against the car is all that matters.
The fact that the base is much larger does not change anything. In fact, it might not fit into the smaller saddle of some jacks.
Quick Reply: Jack pads...are these too small?
