Washing engine bay
I want to degrease and wash my engine bay. What needs to be protected from water? I am not going to pressure wash it, just spray degreaser in there and hose down.
I know many will question why I want to do this. The reason is because it is dirty and I want it to be clean.
Thanks.
The tin foil works well because you can shape it and it will stay in place ok.
"A clean engine is a happy engine". No questions from me about it !!
spray simple green, let it soak a little, I use an old tooth brush on metal parts that have built up grime.
I remove the nozzle from the hose so there is a decent volume of water, but not a lot of pressure behind it. avoid distributor, air cleaner opening, electronics on left side of engine bay. personally, I don't think a little over spray isn't going to kill anything. I also clean off the bottom of the engine and brush where I can.
rinse, then I take the car out for a drive and let it blow dry.
I have done this on most every car I have owned, including 3 air cooled Porsches, and never had any problems.
A clean motor is a happy motor, plus I think my mechanic appreciates it.
http://www.autopia.org/forum/autopia...detailing.html
And always here:
http://www.autopia.org/forum/autopia...yperlinks.html
The end result was a reasonably clean engine compartment.
And always here:
http://www.detailedimage.com/Auto-De...de/Engine-Bay/
Facto AT30 Description:
A liquid detergent concentrate specially designed to add a new dimension to exterior cleaning of modern mass transit vehicles including aircrafts. Safe for use on most hard surfaces including aluminum, lexan, Plexiglass®, enamelled and lacquered surfaces. Excellent in tunnel washers and portable spray units.
