This just started and is occasional for now...
When I turn the wheel to the left the horn will blow. I did a search and discovered this may be a deeper issue for my model year (1996). The parts are no longer available?
If you order a new horn retaining ring..#993-347.088.01 this is a pretty easy DIY
Make sure you have the radio code, you will have to reprogram the radio after horn pad install.
In this order... disconnect the battery.. wait 20 minutes....
Next.. remove the two screws behind the steering wheel airbag, you will need a folding (like a pocket knife or short T-30 torx screwdriver) kind of a tight fit. Now the airbag is loose, gently pull the bag towards you, maybe 3 or 5 inches, unhook the wiring, very simple. Carefully put the airbag in a safe location, pointing AWAY from anybody. Now you can remove the 4 bolts holding the horn pad in place, can't remember the size of the bolts. Install new pad and reverse the procedure. You should only loose the radio, nothing else. Good luck. Mike
Is that the same part that Pags993 is referencing in the post prior to yours? Thanks...really appreciated.
~Dave
Previous owner cut portions of a hose, think thick o-ring and siliconed them in place. Cheap simple solution vs replacing the entire bracket if you are looking for a cost effective route.
Part says 1996-2000
993 and 996 part? Does that make sense. I have a feeling this is a Boxster part common to some 996's
~Dave
Yes, early 986/996 had the Buick steering wheel too.
Early 993 up to some early model year 1996 had the previous part number which is no longer available.
So be carful when pulling apart, even if the car is a 1996, may get stuck and need a part that is not available. If that happens, one would need to source a used part or rig the frame with new bushings or silicon
