Wheels...what the heck is 'ET'?
Besides a favorite movie of a few years ago...
Since the 'rrrr-RRRR-rrrr-RRRR-rrrr' noise I have been hearing seemed to be tire related, and a subsequent balance check revealed both rear rims are slightly out of round, ( Porsche 17" Classic II's ), and the wheel shop wanted $250.00 to 'true them up'...I thought it might be a good excuse to shop for a second set of wheels/tires.
I have been looking at what is available in the classifieds but can't for the life of me figure out what would be a 'safe' criteria size wise for my '95 993 NB C2.
And what does the ET number represent? Any suggestions of what should work on my car? There are some beautiful wheels out there that sellers say work on multiple types, including the 993, but I would like to be sure before I plunk down up to $5,000.00 ( set of brand new Factory Fuchs, 19"...drool...), only to get them shipped all the way here just to find I have to order a bunch of other stuff to make them work, if they will work at all![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
Thanks for the help,
newbie wheel guy, Jim
The term ET originates from the German word 'Einpresstiefe' which translates as 'insertion depth'. It's the distance between the rim's center line and its
mounting surface. One can guess that Einpresstiefe would be important in other matters as well.
Here is what the factory says about wheels.
ET is the standard way to designate the offset of a wheel. It's the distance from the center of the wheel to the hub face.The acronym comes from a German word that supposedly translates as "insertion depth."
I strongly recommend you search this forum [starting, for example, with a post earlier today by nathan1 who's selling a set of NB wheels]. There are numerous threads, many including photos, about wheel alternatives for NB cars.
That rat bastard Schnieder beat me to the punch (line) ![Mad](https://rennlist.com/forums/images/smilies/mad.gif)
Only I was going to say, ET is the title of an 80s decade Steven Spielberg movie.
jakfrost must be stuck in a time warp :-)
Thanks for the .pdf file, at least the factory agrees that 18's are OK. Just wondering how much difference in the ride going from 40 series to 35's would make. We have some pretty nasty road up here in Canada!
I was sorta looking at a set of RH 3.6's, but they are 18x8.5 ( ET 46 ), and 18x11 ( ET 40 ), but sounds like I would need some 'offset' plates to bring them out to ET58 and 66? Or is it the other way around...
Naw...I'm just old
Jim
For a NB w/ 8"/10" you want 50 at the front, 65 at the rear. I like OZ Alleggeritas.
For Aventurine I'd go with --
Black
![](https://rennlist.com/forums/attachments/993-forum/398253d1257741965-new-wheels-oz-alleggeritas-in-black-rls1.jpg)
![](https://rennlist.com/forums/attachments/993-forum/398254d1257741965-new-wheels-oz-alleggeritas-in-black-rls2.jpg)
or, Matte Graphite Silver
![](https://rennlist.com/forums/attachments/parts-marketplace/746495d1374635551-18-oz-alleggerita-hlt-hankook-rs3-094.jpg)
or, Anthracite
- New (most,,, (let's just cut to the chase and say "all",) "used" wheels will need some help)
- Lighter than (almost) anything else
- Tough (they don't bend easily like MY02's)
- Relatively inexpensive
- Very, very Pretty
Black
or, Anthracite
![](https://rennlist.com/forums/attachments/wheel-and-tire-forum/372795d1248205833-the-tire-rack-introduces-the-oz-alleggerita-p1000533.jpg)
And if you choose to go with 8.5" up front instead (and I would,) choose the ET53 offset.
ET54-56 is better**, but unless you're going super low, 53 will do,...
** All credit due to Bill V. for that info
this site helped me to better understand fitment/offset changes...
http://1010tires.com/Tools/Wheel-Offset-Calculator
'mongrelcat'...you said:
"For a NB w/ 8"/10" you want 50 at the front, 65 at the rear. I like OZ Alleggeritas.
Very, very Pretty"
But I'm curious...
Are you referring to 18"...? I used the 'Wheel Offset Calculator' that 'luckyj' sent, it shows that going from a 7.5" to 8.5" (front), as you suggested, with a 53ET, the inner clearance is 8mm LESS, and the outer position would EXTEND an extra 18mm. Do you feel this would be a problem?
The rear, going from 9" to 10" with a 65ET is no problem, basically unchanged, according to the formula.
Thanks all for the great info...you guys are a wonderful resource! Those OZ wheels do look awesome on a green or black car, my Aventurine Green has black, ( semi-matte power coat ) Classic II's and I love the look on the car, so the next set will defiantly be black also.
Jim
Very, very Pretty"
But I'm curious...
Jim
![](http://i1094.photobucket.com/albums/i451/jakfrost1/IMG_1448.jpg)
'mongrelcat'...are these the wheels?
http://www.tirerack.com/wheels/Wheel...All&sort=Brand
The fronts are 8" and the offset is 50...according to the calculator I would lose 4mm inside and gain 8mm outside.
The only OZ 8.5" are these:
And the front offset is 44..? According to the calculator I would loose 4mm inside and extend an extra 21mm...Yikes? They sure are pretty, but for the money the all black look pretty nice!
Jim
Jim
optional on later 993 were 18" 8ET52 & 10ET65
Look here for more info or click on wheel info in my signature line
I believe you have Sport Classic wheels and not Classic II's. Classic's are a one piece wheel that come in 17" diameter; Classic II's are a multi piece wheel and come in 18" diameter. Go to wheelenhancement.com and look at the pictures of both.
I believe the difference between the SC and SC II is that the SC is 7.5" up front, and the SC II is 8" up front. The 17" wheels are one piece, whereas the 18" are a multi-piece.
