JPP Speedster in Pano
#31
Got ours and WOW!!
U R famous now. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Robert wants to keep our copy since it is so cool, but I know I'll come up with a few for you from some of the locals who read and toss.
#32
![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
#33
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
#34
Just got mine yesterday -- WOW! Made me want to buy a cab, ship it to England, and rob a bank. Wait, that wouldn't be enough. Make that start a pyramid scheme based hedge fund....
#36
#37
Also, it seems that each paint color and type can drive each set of processes for each build, such as the color/tint of the primer, how much 'flake' is added into the color, how many coats and block sanding steps are used, how many base coats are applied and 'flatted' before clear etc.
#38
Thanks Jim. I can tell you that the result is a combination of 9m having complete control of the quality of the bodywork and each application and finished sanded state of sealer, primer and paint and clear coat. The finish clear lacquer (lacquer which is no longer available for use in most of the U.S. I might add) is 'flatted' or as we call it 'finish sanded' at the last to remove any blemishes and then polished several times over the final curing days. It is Marc Clowes and Colin Belton who are the mad geniuses behind 9m's paint processes ... they are truly master craftsman at it ... and I'm hoping Colin will chime in here to flesh out the details and keep me honest.
1. To achieve a perfect paint finish starts with the preparation of the panels before primer coats. In all cases we remove every trace of the original paint layers down to the factory primer, and we're talking about the whole car here including door shuts, closures, backs of doors, everything.
2. Make repairs to panels as required with Upol-D aluminium filler followed by stopper-filler. Flat and rework as required.
3. With new panels and those taken to bare metal a light coat of etch primer is applied.
4. Two coats of colour tinted primer. Baked, then left to dry throughout for at least 7 days.
5. Dust coat primer with black and dry flat to achieve perfect flat finish. Invariably this takes areas of the primer back through to metal or filler, hence:
6. More stopper filler work if necessary.
7. Third coat of colour tinted primer, over whole car and all panels, bake & leave to dry for another week.
8. Block sand primer to perfect flat finish.
9. Mask, clean, degrease & prepare surface; apply three or four layers of colour base coat as required. We have two base coat systems, water and solvent. Water base is air dried, solvent base is temperature bake dried.
10. Two or three coats of solvent based clear lacquer as required. Allow to flash off, flow and then bake dry.
11. Allow lacquer at least 10 days to fully harden. Wet flat whole surface with 1200.
12. Apply final top coat of lacquer. Flash, bake & allow to harden for further 10 days minimum.
13. Wet flat with 1200, then 1500, then 2000. This takes 4 days for the whole car. Inspect & repeat if necessary.
14. Polish with coarse, medium, fine & superfine compounds with appropriate foam polishing mops on machine. Inspect and re-flat where necessary.
15. Clean all residue from car, usually with steam cleaner.
16. Final machine polish with glazing compound.
17. Hand glaze, clean and wax polish.
Think that's about it, from memory, but sure that Marc could talk about it for longer.....
#42
![](http://i1087.photobucket.com/albums/j478/jonp356/SpeedArena/SpeedArenaintheshopgarage_zps2ff6020e.jpg)
#43
#44
JP,
Absolutely stunning car and great article! I felt just a slight amount of connection to SpeedArena given my humble '98 AR Cab...amazing that your car started life looking similar to mine, but oh nellie how for yours has come and how far mine has yet to go!
#45
Thanks for the kind words, but honestly, I think the standard Cab is a nigh on perfect design .. and I love your Arena with tan top combo, it's stunning.
