993 Forum 1995-1998
Help diagnose this gnarly noise from my engine (video link)
Old 07-04-2013, 09:36 PM
EMBPilot
EMBPilot's Avatar
Question Help diagnose this gnarly noise from my engine (video link)
Alright, it appeared out of the blue...
i believe it is an alternator bearing but i would like the experts to chime in.
porsche gods are not happy with me this wrenching season
also important to note, during pulley removal to diagnose:
the nut on the alternator shaft, is spinning on the alternator shaft freely without moving. the nut was torqued properly with a crows foot. ive never experienced anything like that before either, not sure what to do to get it off?
Old 07-04-2013, 09:48 PM
EMBPilot
EMBPilot's Avatar
alternator belt cut off. No more noise.
- shaft nut still stuck, spinning on the threads but not moving?
- not sure whats wrong with alternator?
- alternator was showing 12.3 volts at idle before we cut the belt off. no electrical issues.
let the record show, my car is now stuck at quads house in his garage, and quads car is stuck in my garage... wtf...
Old 07-04-2013, 10:15 PM
IXLR8
IXLR8's Avatar
Originally Posted by EMBPilot
The nut was torqued properly with a crows foot.
Was the crows foot 90 degrees to the head of the torque wrench and did you possibly confuse Nm and lbf.ft.?
Old 07-04-2013, 10:21 PM
IXLR8
IXLR8's Avatar
Alternator bearing gone?
Cut the nut off using a Dremel. Keep grinding dust and metal contained. This is going to cost a bit.
If battery voltage was 12.3V at idle with no load, you are not charging. Should be 14V - 14.4V. I sit at 14.1V at idle. Charge the battery using a charger.
Old 07-04-2013, 10:23 PM
EMBPilot
EMBPilot's Avatar
yes it was 90 and im sure it was correct, i recall the value seeming pretty low as well and the wrench having the feeling of it being a lower value.
the only thing i can think of is to attempt to cut the nut off.
with another set of hands i may be able to get a flat head screw driver behind the nut and try turning it with some pressure behind it.
edit: just saw your second post alex, thanks.
once the alternator comes out i'll get it rebuilt locally. not sure what to do about the shaft situation. if the shaft is damaged or if the nut is stripped on the shaft.
Old 07-04-2013, 10:49 PM
pp000830
pp000830's Avatar
Received 1,535 Likes on 1,084 Posts
fan blades hitting shroud. Something out of alignment?
Old 07-04-2013, 10:54 PM
EMBPilot
EMBPilot's Avatar
not the fan cause once the alternator belt was cut the noise stopped so its the alternator. but the nut is stuck on the shaft...
the alternator + Fan and pulleys all together are now out of the car as a unit.
Old 07-04-2013, 11:41 PM
Quadcammer
Quadcammer's Avatar
Received 1,421 Likes on 821 Posts
what a terrible turn of events this was. Thing made noise like a rod was hanging from the case.
yeesh.
Old 07-05-2013, 07:12 AM
IXLR8
IXLR8's Avatar
Long shot....but might the alternator bearings be so worn that the alternator rotor is making contact with the stator?
The noise stopped when the alternator belt was cut off. What does hand rotation of the alternator shaft feel like. Smooth? Any wobble?
Old 07-05-2013, 07:17 AM
IXLR8
IXLR8's Avatar
Cost may not be worth it, but the shaft could be TIG welded up, turned on a lathe and new threads cut.
Old 07-05-2013, 07:26 AM
Quadcammer
Quadcammer's Avatar
thanks for your input alex. By hand things felt ok. I'm no pro on checking bearings. The noise was not present right at start up, it started about 2 seconds after the car was running.
no clue beyond that, I just work here
Old 07-05-2013, 08:24 AM
IXLR8
IXLR8's Avatar
QC, even a bad bearing may feel good.
I checked a fan hub bearing that ran as smooth as a new bearing but was noisy in use and vibrated. Play was ever so slight as well, almost indetectable at the fan blade ends. As good as the bearing felt, the bearing was practically dry.
It'll be interesting to see what you find.
Old 07-05-2013, 09:03 AM
EMBPilot
EMBPilot's Avatar
Perhaps I should just give the entire assembly over to the shop (fan w alt) and tell them to install new fan hub bearing, rebuild alternator, fix nut goes w/o saying.
Old 07-05-2013, 11:08 AM
EMBPilot
EMBPilot's Avatar
Entire thing dropped off at P-Car Indy. Will report back.
Old 07-05-2013, 11:53 AM
MarkD
MarkD's Avatar
late to the thread... sorry
Best I can tell from the video, based on experience it sounded like fan contacting shroud assembly
Which means rear bearing in alternator
I realize yours is out of your hands now, but you would be able to see small marks on the shroud
And if you wiggle the front of the shaft very gently, feel movement in the rear bearing
With the alt belt removed, it very well could have let off enough tension on the alt shaft to avoid contact with the shroud.
I'm sure your shop will sort it out
Good luck!
Quick Reply: Help diagnose this gnarly noise from my engine (video link)
