alignment at new shop...not feeling it really
Well, if they don't clean up...it'll be lots of down time awaiting parts. H&R are still trying to determine compatibility to get me a replacement part number for christ sake...let alone determining available stock on hand. That could be a problem if I decide to take the car to a 2+ hour away shop. I might let the young tech at the dealer(gasp!)look at it first, he has done a handful of 993 alignments. Just so damn hard to arrange return transportation dropping the car off far away.
uggghhhhhhhhhh
So, maybe remove, get dimensions...maybe a number, and go from there. Just because H&R doesn't any longer support individual replacement pieces, shouldn't mean a simple bearing isn't to be found.
many thanks Bill
Un f"en believeable. This was a $4K system installed...just three years ago.
fun, fun, fun
How far is Exotech (Plaistow, NH) from you? Just a thought.
Edit: Exotech is probably too far... (310 miles, 5 hours.)
Hope you get it sorted soon.
Day two, and all I have to say is...H&R USA is a joke, I won't know till Monday if the homeland version if **** too.
Maybe it's just me but, the first contact should have gone something like this.
me " hi, I have frozen monnoballs in your RSS suspension system that cost almost $4K installed three years ago. Can I get replacement part info?"
H&R "sorry, we no longer support that system(pay no attention to the fact that many on-line places still have them in stock), but we used XYZ 12345678 bearings for the top mounts, you should be able to find them on-line."
me " thank you, for the great product support, and customer service"
but noooo, can't be that simple.
Have you ask anyone in the Racing forum for suggestions? Hope you can resolve it to your satisfaction soon...
So, should I assume that these are the same **** quality "stainless" bearings that rusted up solid in just three years?
When I have them in my grubby little mits, I can get all the size details, and address quality.
The next service has been scheduled...two weeks out, at a race shop in Rochester. The shop was reccomended by Joel Reiser, and I had a very enjoyable conversation with the guy there today. Feel good about the place, so that's a good sign.
So to recap;
H&R bad
new shop good
While there are certainly numerous ways that mono ball / spherical joints are manufactured, I would assume that ones used as strut mounts are equipped with a Teflon liner between the ball and the socket. You should see that once in hand.
In your case, the mounts probably experienced cathodic (dissimilar metals) corrosion from moisture, salt, etc. (over time). So if designed correctly, a Teflon liner should serve to both 'lubricate' the bearing surfaces, as well as isolate both metals from each other.
I'm interested in pics of your existing mounts, as well as the new versions.
Andreas
I assume that FK, and Aurora are pure stainless inside and out? Also, with the I.D & O.D., I should be able to cross reference the better bearing.
H&R sucks
