Clutch slave bleed gone bad?
2. I go to great lengths to NEVER bottom a master cylinder (clutch or brake). This protects the seals from a premature failure due to being pushed over rough & corroded spots in the MC bore. Pumping the pedal to the floor is an accelerated path toward buying a new master cylinder.
I sure hope this helps save someone from an expensive & unnecessary expense.
I use one of these, best $30 I spent at H-F:
