Clewett kit finally installed!
#32
I can't quite figure out improvement this makes on a street car. I can imagine that it's more reliable on a track car that operates at sustained high RPM's. But on the stock setup, pretty much the only cause of problems is operator error.
#33
LWC has been excellent..... For my predominately track orientated beast.
I have a high idle (over 1000 rpm) and the charging etc is not a problem. While tuning my car when the idle was below 900 ish I did notice the charge rate dropped considerably.
I would think that for stop go motoring this could be a problem potentially damaging the battery due to undercharging.
As NP993 stated not a good upgrade for a street car.
For my car that rev's very quickly and rev's high (7500) it is a necessity, for many others save your cash
#35
Seared
That's my concern too. I was thinking about the RS pulley mod or the serpentine
belt mod but have reservations about the idle speed charging rate.
Yesterday I did a small test to see what the stock 3 belt system does at idle.
See this thread:
https://rennlist.com/forums/993-foru...ing-rates.html
I read somewhere that the RS pulley mod puts out about 12.6-12.7v at idle.
I would assume the serpentine belt mod does the same. Doesn't look like
much reserve for accessory loads.
See this thread:
Here's a few pics of the recent surgery:
![Name: D8F20BFF-EE32-48A0-92E5-D4E866D2C91F_zpsbilhh65c.jpg
Size: 124.1 KB](https://rennlist.com/forums/attachments/993-forum/1230281d1501528286-clewett-kit-finally-installed-d8f20bff-ee32-48a0-92e5-d4e866d2c91f_zpsbilhh65c.jpg)
![Name: C9FAC068-4960-4D82-B67B-D924DCAC49FC_zpsry5sfjm7.jpg
Size: 133.3 KB](https://rennlist.com/forums/attachments/993-forum/1230282d1501528286-clewett-kit-finally-installed-c9fac068-4960-4d82-b67b-d924dcac49fc_zpsry5sfjm7.jpg)
![Name: ED1D849B-5281-464D-80C1-C865DBD2CFC6_zpsltakaujt.jpg
Size: 180.1 KB](https://rennlist.com/forums/attachments/993-forum/1230283d1501528286-clewett-kit-finally-installed-ed1d849b-5281-464d-80c1-c865dbd2cfc6_zpsltakaujt.jpg)
![Name: 6B1EF445-E85A-4B69-B14D-F99CD2F09BC6_zpsa9vqn0h5.jpg
Size: 138.0 KB](https://rennlist.com/forums/attachments/993-forum/1230284d1501528286-clewett-kit-finally-installed-6b1ef445-e85a-4b69-b14d-f99cd2f09bc6_zpsa9vqn0h5.jpg)
![Name: AA626A8F-D06D-4215-8E86-E235DBA56098_zpsofwf10hy.jpg
Size: 190.3 KB](https://rennlist.com/forums/attachments/993-forum/1230285d1501528286-clewett-kit-finally-installed-aa626a8f-d06d-4215-8e86-e235dba56098_zpsofwf10hy.jpg)
![Name: D8979F0B-CE8F-41A9-8D93-A319B4848732_zps4bzw3lnf.jpg
Size: 190.7 KB](https://rennlist.com/forums/attachments/993-forum/1230286d1501528286-clewett-kit-finally-installed-d8979f0b-ce8f-41a9-8d93-a319b4848732_zps4bzw3lnf.jpg)
![Name: 10C9DC5D-5F8E-4C49-B767-12F8625033F4_zpsweeesfo7.jpg
Size: 136.8 KB](https://rennlist.com/forums/attachments/993-forum/1230287d1501528286-clewett-kit-finally-installed-10c9dc5d-5f8e-4c49-b767-12f8625033f4_zpsweeesfo7.jpg)
Andreas
#36
Looks great! Your voltages look close to the money - I found with the RS setup, in the winter, with the defog on/lights/heat/stereo/heat seaters on, my pre-HID headlights would actually dim when idling at a stoplight. That was after driving in city traffic with a lot of stop and go. It would not show up on longer runs (like 500 miles you mentioned) at all. I also had the Targa, and the roof sucks a lot of amps when opening, so if the car was idling, after a lot of loading, the motors would not get sufficient power and the roof would stall opening while the car sat there idling. If I pulled away and then tried it, the alternator was spinning fast enough to supplement the current draw and the roof would operate fine.
I like the looks of this solution, it's a nice and clean alternative to the RS option.
Cheers,
Mike
Cheers,
Mike
#37
Seared
![Name: 09CF420D-87B6-44EA-B4FA-78BBB4FF3F25_zpsniyll1ik.jpg
Size: 130.5 KB](https://rennlist.com/forums/attachments/993-forum/1230280d1501528286-clewett-kit-finally-installed-09cf420d-87b6-44ea-b4fa-78bbb4ff3f25_zpsniyll1ik.jpg)
Andreas
#39
Seared
I replaced it once a few years ago. When I removed the 'newer' one last month, I found the bearing dust cover was gone and the ball cage was in the engine tin...
Andreas
#40
(There's a sort of companion SCCA GT-2 914-6 in the classifieds now, built by another of our '80s Phoenix gang.)
#41
#42
Seared
It's a nice mod with the exception of less voltage at idle but it's not a real problem. I had the kit in my previous 964 for over 50,000 miles. Used it a a DD without any difficulty.
#44
Andreas,
Welcome to the club! I haven't had an issue since installing 2 years back. Much more confident than ever in driving on long road trips, etc. without worrying about a belt breaking and changing on the side of the road. Also - never have to worry about any adjustments.
Enjoy!
Enjoy!
#45
Andy
