Oil brand@weight?
gosh, wouldn't it be cool if we had, you know, talked about oils once before.
snark aside, do a search, the reading will keep you busy for the next 2 weeks.
What coolant do you recommend? Green, orange or clear?
Mobil-1 15-50
Received 5,411 Likes
Look into Joe Gibbs DT50 15W50.
20% off through tomorrow at L&N Eng.
Code 20OFFOILS
Code 20OFFOILS
Received 1,043 Likes
Although I generally shy away from "use the search function" replies, I completely agree with those above.
Oil discussions have got to be the most discussed (over discussed more likely) topic on this or any other P-car forum. Quadcammer said you'd be busy for two weeks..........I'd bet more like two years. The volume of reading material is simply mind numbing. The subject of said reading has similar effect.
RL Technical Advisor
In the same spirit,...
I use & recommend (and sell) in no particular order:
1) Brad Penn Racing 20w-50
2) Motul 300V 15w-50
3) Mobil 1 V-Twin oil 20w-50
There are some other good ones too, but I've had good luck with the above products and really like what I see on bearings, rings, cams, rocker arms, pistons, etc.
