993 Forum 1995-1998
Motorsound? Caliper? Help?
Old 09-22-2013, 11:32 AM
  #31
tcsracing1
tcsracing1's Avatar
so just so i am clear, all i need to do is drill these holes to get the "motor sound" package?
nothing else?
Old 09-22-2013, 12:11 PM
  #32
luckyJ
luckyJ's Avatar
nothing else?
+ the motor sound mufflers
Old 09-22-2013, 12:29 PM
  #33
Beretta
Beretta's Avatar
Nice done.
But you can really simplyfi this drilling..bigger holes and more holes.
Draw a square diagram over the plastic cover, the pre drill with a small 4 mm, then go up to 10 mm and open up the holes.
Put back in car, take it fore a ride
Old 09-22-2013, 01:34 PM
  #34
FabianS
FabianS's Avatar
Adam, where you still going to send the template around?
Old 09-22-2013, 01:35 PM
  #35
tcsracing1
tcsracing1's Avatar
I assume a set of Fisters would suffice?
Old 09-22-2013, 01:59 PM
  #36
Pags993
Pags993's Avatar
^^^ order the Fisters and forget about drilling the holes. I had a set of Fister II's before drilling the holes and noticed no difference in sound whatsoever. Nice excuse to bust out the drill and punch a bunch of holes really LOL
Old 09-27-2013, 02:22 PM
  #37
Seamless
Seamless's Avatar
Template has been sent to FabianS. Sry about the wait.
I included a new twist drill and machine screws/nuts to hold it in place while drilling. I made sure the machine screws were Robertson drive to confuse the 'mericans using it
Enjoy all!
-Adam
Old 09-27-2013, 07:40 PM
  #38
Ponchobroke
Ponchobroke's Avatar
Why not just cut out the entire back of the box?
Old 09-27-2013, 08:41 PM
  #39
jg291446
jg291446's Avatar
And if you remove the box, will it give a good idea of the sound with a drilled box?
Old 09-27-2013, 09:08 PM
  #40
luckyJ
luckyJ's Avatar
oh definitely...I use to hear a whining sound coming from the rear with the motorsound mufflers and respective airbox cover....but after installing the Fister IIs...all I hear is the sweet growl!
Old 09-27-2013, 09:24 PM
  #41
Ponchobroke
If you remove the box entirely you will expose the MAF and, I would expect, create undo turbulence going into te MAF. I just decided to take out he back while sill retaining the ability to hold the filter. At he same time I took off the tranny hose to the filter box and sealed the hole in the engine tin with a piece from the cover. Some have replaced with tin from a Tip.
Old 09-27-2013, 09:36 PM
  #42
NP993
NP993's Avatar
At first I thought this thread was a parody, but no, it appears to be real.
Quick Reply: Motorsound? Caliper? Help?
