What tool do you use to adjust the headlights?
What tool do you use to adjust the headlights? It says to turn the adjustment screws in the manual, A for left and right and B for up and down but its not a screw, its a little nut at the end of a tube. Does anybody know what tool you use to get in there?
Thks
G
Thks
G
Yes, it's an allen wrench. Be VERY careful when making adjustments. It's probably good technique to take headlight assembly out of car and turn each screw a little to see how they turn. I found that the plastic adjusting gear bolt (which is turned by the adjusting screw) can easily get chewed up if they bind. You can take off rear of headlight assembly and spray a little silicone lube in there to help things turn easier.
Unfortunately, if you chew up these screw-bolts, you can't buy them individually. Ask me how I know.
Would also recommend you don't try to make large adjustments on a single screw as each adjustment also affects the other. Go back and forth between the adjusters. I also found the manuals description of what each screw adjusts to be a little off, each adjuster affects both axes, one more so than the other of course.
Well the level is very easy to get due to the spirit levels in the headlight but as to how the lateral adjustment is read I have no idea.
At least they are both at the same height and a visual inspection of the lens certainly seems to appear to favor to the right towards the side of the road.
I'm twisting the A screw and it also seems to affect height more noticeably than it affects any side to side movement.
G
G
The old H4s from the SC and 3.2 Carreras had a lense that was designed for that. Not sure if the internal 993 reflector is also designed that way, but Porsche was ahead of its time in doing it on the SC, and perhaps even prior to that.
G
G
Thks
G
I see the little measuring stick off to the inside of each of the light assemblies, but when you say 'Adjust the left/right position so it's dead on that longer mark', what exactly do you mean? The bulb can't point towards it directly can it? Do you mean the beam of light? The edge of the beam of light? Sorry to be so dim about this.
Thks
G
Thks
G
I say "approximate" location because sometimes the lights don't fully align to where they should be shining (on a wall up ahead, etc.) There are factors that can influence your alignment - including ride height (suspension modifications), different tires than originally designated for our 993's, and inherit slop in the headlight assembly. You also have to make sure you are on level ground with the appropriate tire pressures and the suspension is truly settled.
Thks
G
Thks
G
Actually, what Bill is referring to is to use your markings as a reference as to the "approximate" location of where to align your headlights. The larger hash mark on the marking stick should just be visible as well as the bubble in the center of it's marking stick (set to 0). Unfortunately, one adjustment screw can effect the other one. So you have to play with BOTH adjustment screws until they both markings are set at these locations we described.
As Mgianzero says it won't be perfect but is a darn good starting point from which to tweek in your adjustments based on the other variables.
while you can get kinda close with the levels, you have to put the car at night in front of a wall and dial it in... mine are too low and I need to increase their height...
"While not being exact, if you adjust the horizontal to the longer mark on the measuring stick"
I'll have a look tonight and see whats going on here. I'm sure it quite straightforward but I'm having a hard time visualizing what exactly right is supposed to look like in regards to how the measuring stick.
Is the light from the element supposed to fall across the longest mark or is the longest mark supposed to be just visible out of the casing?
I laughed a bit when I saw the description in the manual as its all incredibly vague. Hopefully I can get my head around it tonight.
G
G
The longest mark is to be just visible out of casing. The light does not project itself onto the alignment markings whatsoever. It's a very simple design.
For the "in-the-lights" adjustment you don't even need to turn on the headlamps, just adjust the screws (5 mm hex bolts to be exact) for the measuring stick and the bubble to be in their proper settings. You're adjusting the headlamp assy., not the bulbs themselves.
