how many quarts of oil in oil change?
I have the side fill oil tank with no dipstick... so how many quarts of oil do you drain and add during a normal oil/filter change?
Received 5,407 Likes
A normal oil change on a normal 993 is 10 quarts. Not sure exactly what you have. Do you have a way to measure what's coming out, and add the appropriate amount back in?
I'd disagree with this. I consider a normal change to be both filters, and mine typically takes 10.5 qts. This is very much on par with my old 911.
Thanks guys... Looks like I might be filling about a quart or so low.
fyi... my oil tank/breather system shown below for those who asked. Have 8micro canton filter / thermostat in front before coolers - hence no filter / thermostat on bottom of tank.
