door check strap weld cracking
I wish I could get a pic of mine. It's in storage right now. I had Dave Triechel from Zero to Sixty garage correct it. He did such a great job, it looks like it came that way. He welded completely around the hanger. From the top around the back and underneath. At first I was concerned because the hanger appeared to be crooked, but he said purposely did this to make the hanger and area around it stronger. He then finished it (or maybe it's just a good weld job) by making it appear like a "fillet" and he painted it to match. Unbelievable job. I have nothing but praise for all the work he's done on my car.
http://www.zeroto60garage.com/Main2.htm
A good welder can do it properly when you show them pictures from the link. That is what I did to get the job done right. My door check strap was repaired before and had a lot of material on it but it cracked at the base. I was told that the temp was not high enough when doing that weld to make the material stick long term.
I don't know much about welding but was told something like too low of temp will not stick properly. Too high of temp can melt and wrap the metal you are laying material on?
I had a similar "PPI surprise":
![](http://images61.fotki.com/v666/photos/7/168597/10685985/ppisilver9930011-vi.jpg)
More concerning to me than the extremely poor repair was the potential for rust if neglected. I had it cut out and boxed, which IMO is the proper repair:
![](https://images60.fotki.com/v361/photos/7/168597/10685985/IMG_2980-vi.jpg)
http://www.mwautoservice.com/
Wouldn't hurt to give Jay a call at M&W up in Stockton. He's the only guy I'll let work on my 993.
Sent from my iPad using Rennlist
Do not have any blow by blow photos, but to my recollection, the body shop cut an access into the area on the side or back of the pillar located near door check mechanism, welded an additional solid support piece to keep the door check firmly affixed and in place. There is little welding done externally as I have seen on this thread. Nice clean job done to Porsche certified specification as apparently there is only one way to really do it right according to Porsche.hope that explains okay...
the PO fixed the door check strap by welding underneath only, it starting clicking about a month ago.
as you can see in the picture the weld has started cracking.
i would like to fix it, but wanted to see if this has happened to anyone else.
should i find someone to grind away the existing weld and weld new again?
is it normal to have the weld fail after some time?
would it be better to weld top and bottom?
i have searched but not found a post with this situation.
bonus points to anyone that can refer someone in the miami area that has done this repair before.
thanks,
Neil
thanks,
Neil
Cheers
Allan
Metal fatigue is pretty common right beside welds on parts that are still allowed to flex. The filler metal from the MIG wire is actually harder than the metal you are welding and has a different crystalline structure because it has cooled very rapidly (unavoidable). This car is on the way to looking like Gary1101's. The only way to prevent it is to reinforce from the backside so that the bracket cannot move.
Cheers
Allan
Cheers
Allan
https://rennlist.com/forums/993-foru...k-strap-3.html
See my post #36 in how we addressed the issue "done correctly."
thanks,
Neil
thanks,
Neil
I'm not a welder, but that weld on your repair looks terrible to me. Would not be surprised to find that the crack was in the weld from day one!. I would have the weld ground out, and then prep the area for cleanliness before attempting another weld. I would get a different welder to do the work. And, by all means, weld out the top and the bottom of the stay. You can then dress down the weld with a Dremel tool. And, then repaint the area. But, all that grease has got to be removed so that the repair is not contaminated.
Does anyone have a photo of the inside of the pillar? I would like to offer a suggestion to how the reinforcing plate should look. BTW these parts are all zinc coated from the factory the coating needs to come off before any welding takes place.
Better have that "Lifetime Repair" in writing.................. . . . . .. . ..
LOL......have no worries about the shop repairing it.....if it ever breaks again........I had my rocker panels painted in 2005 with the same guarantee from the owner and due to very slight discolor after I called them on it, the shop repainted them at no charge in 2016.....I generally build good relationships with indies or contractors that I have work done with, whether my car or house, and find people will honor their word if you are civil and treat them with respect....been lucky that way with anything that needs a redo...
