Group Purchase on Atlas Scissor Lift
#211
Fellow midrise users....
i would like to solicit suggestions as to what support accessories you are using in addition to your lift. Something along the lines of a pole jack?
im looking to get away from bottle jacks and 'custom' wood creations, gives me a lot of anxiety. id prefer 'the right tool for the job'. Im not coming up with much when search locally as far as options... the ones i do find are way too big, used under a full rise lift.
Untitled by , on Flickr
![](https://c1.staticflickr.com/1/536/32715950495_d5ba357cb0_z.jpg)
#212
Are you finding that your car teeters or rocks around a bit while on the lift? I have never used any additional supports nor really felt the need to up to this point with my Atlas lift. To be fair I have never done anything more major than brakes / suspension / tire rotation while on it, all of the cars have felt very stable on it.
#214
![](https://cimg7.ibsrv.net/gimg/rennlist.com-vbulletin/800x600/motorsupport_zpsidd7ronh_acc6db5a7c9431ac9af537a70002642703ca0e14.jpg)
#216
I'd agree that custom stands aren't a bad way to go.
For engine drop, I've always used an ATV jack with a 1" ply platform bolted to it. With the trans dropped at the same time, I used a scissored transmission jack to support it. Worked well.
Truthfully, with multiple drops and multiple cars, I've really not needed accessories, other than the above.
#217
How about one of these and trim the height down if necessary:
https://www.amazon.com/Sunex-6809-4-...st+Stand+small
#218
#219
These supports seem to only come in the size for a full rise lift. So i bought full size one coreseller found, then shortened it to about 24". It can extend to roughly 40". Between the plate and the pipe is a large bearing race, so even while there is a load on it you can raise and lower the support.
![](https://c1.staticflickr.com/3/2922/32044137194_44eb34ffa7.jpg)
![](https://c1.staticflickr.com/1/538/32886689725_0850a41e06.jpg)
