Leakdown/compression results - 993tt
#31
but, you posted in the wrong forum, asked for advice and despite all the comments didn't take the advice... why did you ask? if you're going to ignore us anyways!
Car looks great, but the exhaust tips a little low - could be just not adjusted properly or could be bad engine mounts...
#32
The car has had 4 owners and 3 are related and have had the car since 2003. I have all books and records since birth. PPI was superb-- but when I saw the leakdown numbers I freaked out and was extremely disappointed as I had set myself up for 4-6%. I immediately posted. But I came to the conclusion (after digesting all of the comments and reading alot about the test) that MarkD (and you) came to.
I almost didn't even do the test. I previously walked away from two 993tt in the last 60 days due to the PPI. But this one feels right (I did drive it) and I am going in knowing the possible problems (however remote the risk). Had everyone said "walk away" given all of the facts, I think I would have (I'm not emotionally tied to it just yet).
Thanks to everyone for taking the time to offer their thoughts and advice and I hope this thread helps others in a similar situation. It is much appreciated.
#33
#34
Good move ditching the tint and the chromed wheels - it looks great! Good luck!
#35
Oh, and about those exhaust tips-- which is the only modification on the car (besides the tint (yuck!) and the wheels)-- I agree. But upon quick inspection, it looked like I'd have to raise the cats in order to keep everything level and not angle the tips. After the tint and wheels, that will be next on the list.
cheap and easy fix though
#36
Hmm, not sure if I agree. It seems to me that at 100psi, you might start to observe leaks that do not happen at 35psi, so the reading could be different. I mentioned that in my post. For example, the rings may be able to hold a 35lb pressure fine, but at 100psi fail a bit (like you said, closer to operating pressures).
cheers,
Mike
cheers,
Mike
To the OP, sorry for derailing. I think a lot has to be said for the gut feeling you have, especially if you've experienced a few different examples. Your tone indicates you will not jump into something without due diligence so thanks for posting and replying and letting us in on your process.
#37
Don't know if it's your tech telling you this but the level of the cats is not really adjustable/ can't be raised. You can slightly adjust how the mufflers and the exhaust tips sit, or it could be the engine mounts that can fail/leak as mentioned previously.
#38
Mike, I totally agree with higher pressures creating leaks possibly not present at lower pressures. My response was regarding the % maths calculation - I meant that from any starting pressure you can calculate a %. The key is, if all the tests are done at the same pressures, then that % can be used as a common currency that we can all compare. Different pressures = not directly comparable % values. Sorry for confusion.
They are Fabspeed tips. Once I get it here locally, I'll see what can be done 'cause they do need to move up a bit.
#39
Sagging muffler tips usually mean bad motor mounts. Tips pointing in the wrong direction probably need adjustment. 993s are very different cars compared to 996s and 997s.
#41
Did the PPI identify the out-of-alignment exhaust tips, and provide a cause?
Good luck with the car, but those test results would be sitting in the back of my mind until I get confirmation it's ok. Maybe I have seen too many cars, I had a Turbo in the shop late last year, just had a rebuild (with 28,000 miles total on the car!), ran great, smooth idle, pulled as it should - did a PPI and found one cylinder at 25%. Rejected the car, and it went back to the owner to fix.
Low mileage does not mean there are no internal issues, especially on these cars. They can be damaged and abused even at 100 miles.
However, sounds like a great car and also this stuff does not appear to worry you much, so great - really enjoy the car!
Cheers,
Mike
Cheers,
Mike
#42
Congrats! It's hard not to get emotional that will cloud your judgement before a purchase, but the decision is made now and appears your happy with it, and that's what counts at the end of the day.
So what kind of wheels are you going to swap them out with?
Totally agree no chrome and no tint!
#43
Doesn't really matter now but the 35psi leakdown tester reminds me of those that sold in Harbor freight. Because they would only hold up (or calibrated to 35psi max) so they are junk. I bet that is what the shop is using. Nothing against HB (they are great for home use sometimes) But a reputable shop using equipment bought from Harbor Freight would at least gave me a pause.
#44
Spyder34, It's a beautiful car but I agree to ditch the chrome wheels.
My advice would be to get a second leak down test conducted by a known reputable Porsche indie shop, with new leak down result you might get some sleep at night. While there ask them about the lowered tail pipes to be sure the motor mounts are in sound condition. It's better to pay a little now rather than pay a lot later.
#45
Cheers,
Mike
Cheers,
Mike
Great idea-- I'm thinking the same thing-- recs on local Chicagoland shops?
