If you can redo your mods all over again...
Would definitely do these again:
HID- better light and back to normal since my last sports car had HID.
Fabspeed xpipe- nice sound felt the weight drop and the power increase.
Here is my $.02. The car is strickly a street and AX the car. I used to DE, TT the car. Approx 10 DE,TT events before going to a race car and putting the 993 back to street.
Mods -
KW v3 Coilovers
RS Adjustable Sway Bars
RS Uprights
FDM XL Rear Drop Links
RS Engine Mounts
RS Engine Carrier
Walrod Front Bushings
Walrod Aluminum Gauge Rings
RS Strut Brace
RS Alternator Hub
RS Heater Bypass
Golden Rod
FDM Short Shift Kit
Polished MY02 Carrera 5 Spoke
OZ Alleggerita HLT Wheels
Sparco Evo2 plus Seats
Hard Back Sport Seats in Speed Yellow
DAS Bolt-In Roll Bar
Schroth 6point Harnesses
RS Steering Wheel
RS Shift ****
OEM Aluminum Brake Handle
Fister Ceramic Stage III Sport Mufflers
FDM SS Wide Ovals
Rennline Solid SubFrame Mounts,
Rennline Track mats,
Rennline Dead Pedal
Rennline Fire Ext. Mount
WaveTrac LSD
Light Weight Fly wheel and clutch
Brey-Krause Sub Strap Mounts
Odyssey Light weight battery
Rennline Battery Mount
Now the car is back to Street/AX I have removed
RS Heater Bypass
I am planning to remove
RS Alternator Hub
All the rest make the car a REALLY Nice street car.
Let me know if you would like a detailed analysis on any individual mod.
Have Fun!
Mods -
KW v3 Coilovers
RS Uprights
RS Engine Mounts
RS Engine Carrier
RS Strut Brace
RS Alternator Hub
RS Heater Bypass
Golden Rod
FDM Short Shift Kit
RS Steering Wheel
RS Shift ****
FDM SS Wide Ovals
Rennline Dead Pedal
WaveTrac LSD
RS Heater Bypass
RS Alternator Hub
Have Fun!
For the 4S, which was a 100% stock 100K mile street car when I got it in '04? It's still pretty much stock, save for a wider front tire and PSS9 kit. Today, for a street car, I'd install a very well-valved non-adjustable damper to match whatever spring rates I felt would work best on a street car. And the wider front tire. Nothing else about the car bothers me, from as-delivered spec.
For the yellow car? Well, glad I lucked into a 100% complete, low mile/use, professional build of what a nearly full-weight 993 track car should be. And nine years after it's completion, there really isn't much that's evolved to change how such a car would be built in 2013.
So considering I probably couldn't trade the both of them for a new base, stripper Cayman, they'll stay as-is. (Figuring out when I can drive either continues to be the challenge............)
The only disappointing upgrade I have is the LWF. If I were to do it all over again, knowing what I know today, I would avoid it at all costs. (unless it was a track car and only a track car)
My mods are in my sig. I don't regret any so far.
Safety wise I think the HID lights are the best bang for the buck.
Appearance wise I am glad I totally love the nose. I have the RS splitters with Turbo S fog light ducts, clear corners, and bumpette delete. All the trick pieces are, but the bumpetter delete is what I really love.
Family wise I added LATCH points and bought car seats that fit. Nothing wilder then a Porsche family hauler.
LWF/Clutch, Fister IIs/Fister SSK/PSS10s/RS motormounts/Walrod bushins....great performance upgrades that I wouldn't trade. Fun to see all the different ways these cars have evolved! All good from stock-up.
Cheers,
Mike
I guess I'm with Mike in that buying the turbo was the best upgrade. The car had H&R row suspension and HID lights when I bought it, and all I have done is Walrod bushings, in terms of performance improvement.
Beyond that, Im just fine with my upgrades. I have other plans for my vehicle, which I wont comment on now because people will just want to know how much...........................
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
I think for a street car that sees the track occasionally:
1. HID lights
2. PSS 9
3. muffler upgrade
4. CDR 220
5. walrod bushings
6. 996 3-spoke steering wheel
if you are more track oriented
6. RS sway bars
7. DAS roll bar
8. bucket seats and 6 pt harness
9. semi solid engine and tranny mounts
10. RS clutch and LWF
11. regear transmission (only if it needs repair)
12. Motor sport LSD that can handle track duty
I did not spend a lot of time on the exact sequence
1. HID lights
2. PSS 9
3. muffler upgrade
4. CDR 220
5. walrod bushings
6. RS sway bars
7. DAS roll bar
