Oil leak - advice please
Towards the end of the summer I started to notice a drop or two of oil on the floor each time I drove the car. Upon investigation, I found oily grime beneath the VRAM, and also a drip between the heads and the cylinder number 3.
Where would this oil be coming from? Does this mean a top end is required? Also, the oil return tubes are looking a bit rusty. Do they need replacing immediately, or is it normal for them to look like this on the bottom?
![](https://rennlist.com/forums/members/paul902-albums-oil-leak-picture19182t-img-0451.jpg)
![](https://rennlist.com/forums/members/paul902-albums-oil-leak-picture19179t-img-0454.jpg)
![](https://rennlist.com/forums/members/paul902-albums-oil-leak-picture19180t-img-0455.jpg)
![](https://rennlist.com/forums/members/paul902-albums-oil-leak-picture19181t-img-0457.jpg)
Pictures help as well.
Corrosion on the oil return tubes is not biggy, if not ugly. The concern is are they leaking -> to replace them you will need to pull them out and put in the expandable ones.
The VRAM always seems to sweat or accumulate oil in the intakes, often leaking from the bottom activator, then getting oil all over the intakes. Its not an operational issue, but its messy.
Are you getting oil between the head and the cylinder body, or between the head and the cam carrier? That is more likely, or is it oil from above leaking down?
cheers,
Mike
cheers,
Mike
https://rennlist.com/forums/993-foru...-manifold.html
These things leak. Almost all air-cooled 911s do. Chances are it's no big deal. The cheapest and most effective fix is to add more oil as needed and keep an eye on the leak.
If you don't wrench yourself, have your trusted mechanic eyeball it at your next scheduled service and fix it then
Paul,
If your oil return tube O-rings are leaking and you need to replace them, here are your possibilities...
According to what I've read, the one-piece oil return tube require some engine dis-assembly. Why Porsche didn't install them from the valve cover end...
...who knows.
Porsche's one-piece oil return tube...
![](http://edelweiss.smugmug.com/Cars/Porsche-Technical-Stuff/Oil-Return-Tubes/i-LCcSGKm/1/O/Oil%20Return%20Tube%20-%20OEM%20-%20One%20Piece.jpg)
Porsche's and aftermarket two-piece oil return tube...
![](http://edelweiss.smugmug.com/Cars/Porsche-Technical-Stuff/Oil-Return-Tubes/i-qSnrkPK/1/O/Oil%20Return%20Tube%20-%20Two%20Piece%20-%201.jpg)
Same as the one above, but nicer looking with a price to match...
![](http://edelweiss.smugmug.com/Cars/Porsche-Technical-Stuff/Oil-Return-Tubes/i-tDzLgnW/1/O/Oil%20Return%20Tube%20-%20Billet%20Aluminium.jpg)
Yup, just cut out the old ones and put in the new expandable ones - given the design was from the original engine, who knows why it was done this way?
Cheers,
Mike
Cheers,
Mike
Hi guys, thanks for the comments. Does nobody see the photos in my original post? I can see them, but it seems you cannot. Let me know if you cannot see photos and I will try reposting.
I think the oil return tubes are not leaking, just look rusty, so I am trying to judge the urgency of changing them. The leak from below can be seen in the second photo (if you can see them). There is a square boss on the cylinder and the drops are coming from between that and the head. I degreased everything and ran the engine a bit and this seems to be the main leak source. It is ahead of the furthest forward oil return tube.
Do the two piece tubes work as well as the one piece? Any leaking issues?
thanks,
Paul
thanks,
Paul
There are no pictures that I can see in the original post - not sure why it does not work, or how you posted them.
If not leaks on the tubes, leave them. You can get some of the corrosion off using emery paper or something finer. If no leaks, no urgency.
Cheers,
Mike
Cheers,
Mike
Just read the thread that Keith linked to. Hmmm, I wonder if I have this causing the mess up top and something else leaking at the cylinder to head interface?
Thanks, Mke. I uploaded the pics to a RL album then tried to paste them into the post #1 from there. Seems only I see them (and I'm not drinking, yet...). Let me try again...
Try clicking on the Edit icon on your orig thread. Click on Go Advanced. Then scroll down to Manage Attachments. Then click Browse to look for your picture where ever it's located in your computer. Hope that helps.
Edit: Oh damn Alex. You beat me to it.
