Porsche Technical Bulletin on 993 Tires and Wheels
I have found this Bulletin to be very helpful, especially when trying to visualize a specific wheel...noting there are 15 different wheels that Porsche offered for sale on the 993.....alas, I tried to attach it the complete bulletin...too large, so I have attached only the data on wheels...whoops too large too....
if you care, e-mail me and I'll send to the pdf.
I have a Porsche factory technical bulletin that specifies all the tire and wheel options for the 993 car. The pdf file exceed the maximum for Rennlist...so if one wanted the file, send me an e-mail mfschacht@gmail.com and I'll e-mail them the pdf file, still confused?
This should help ...
Wish I could figure out how to view more than the first page of the TSB. I looked up the summer tire bulletin, and couldn't get past page 1 of 10. I'll have to try it again.
36/44 tire pressure for 18s seems really high. Is it because current tire technology can manufacture a sidewall that is stiffer with less pressure now?
Good question. There was a recent thread with a lot of discussion on tire pressure but no real resolution...at least based on fact. FWIW I run 36/44 on my C4S with twists and Conti DW tires and on good roads it feels great...on marginal surfaces it feels like a bit too much pressure. The problem is there are so many variables...I am at RS height with PSS 10s set at 4F/5R, etc etc. Porsche was real adamant about not running any lower pressure...most likely due to some cars being run at very high speeds. Is there any verbage from tire manufactors or Porsche on the current generations of tires that recommends running lower pressure?
I suspect that there is also a bit of liability involved. So the recommendation may not necessarily translate to optimal performing, but what the Insurer deems as low risk.
I know some people believe that just because the factory recommended it or designed it that way, it must be the best performance. Likewise there are other forces in play like money, federal regulations, insurance risk etc...
in any event, clearly there are many other tire choices available now that were not available at the time of the bulletin.
button queen
Any exparts out there that can help beyond the speculation on insurance risk?
Nitto NT-01 Tires:
245/40/18 front
275/35/18 Rear
On the rears, the next step up is a 305 tire and I don't want to buy one to see that it fits...it does't look like I have 30mm of extra clearance available.
In 17"
235/40/17 Front
275/40/17 Rear
Again NT-01
I buy them Heat Cycles too, and extra $15 a tire.
245/40/18 front
275/35/18 Rear
In 17"
235/40/17 Front
275/40/17 Rear
Again NT-01
Another question is what is the tallest tire one can run on their 993?
Here are a few numbers:
265/35r18=642.7mm 25.3 inches
265/40r18=669.2mm 26.4 inches
270/40r18=673.2mm 26.5inches
275/40r18=677.2mm 26.7inches
275/45r18=704.7mm 27.7inches
