Porsche Technical Bulletin on 993 Tires and Wheels
Keep in mind, different makes and models of tires will be slightly different.
There can also be variations from car to car, recall that the 993 was also partially assembled by hand. The 993 was the beginning of Porsche's transition to Japanese auto manufacturing, hence the increased production numbers in the subsequent 996.
I am running 225/40 and 285/30 Sumitomo HTR Z IIIs on 18s. RoW M030 springs and Bilstein HD shocks. If I were to go with a different tire, I would probably go 265 in the rear as that will probably be more neutral, although I like the way my car currently handles.
I am not sure what you mean by performance issues, some combinations will be more under steer or oversteer than others, but where you want to go depends on where you are now.
If you search, there is a really good oversteer/understeer listing that tells you all the ways to increase one or the other. I used to have it bookmarked, but all got deleted when we got a new Mac at home.
Thanks for the feedback, performance issue such as decrease 0-60 performance, increase fuel consumption, decrease top speed. Because I was thinking about going with 235/40r18 front and 275/40r18 rear or 225/40r18 front and 275/45r18 rear for a different look with the taller side wall profile.
The taller the sidewall, the better the ride. I was running 285/30/18 rears with the proper front tires....shook the fillings out of my teeth. Git rid of the tires and upped the side wall size (%age of tread width). For the track....I use the lowest profile tires I can mount up.
A nice street set up, track too for that matter is:
Front: 225/40/18
Rear: 265/35/18
The track junkies may stay "nay-say" on this...but also remember that these slightly smaller tires could very well be lighter, they for certainly be cheaper.
Front: 225/40/18
Rear: 265/35/18
The tire pressure page from my 993 owners manual: My question is why would a small increase in tire size create such a large decrease in rear tire pressure? Even though the manual recommends 36 rear (44 with 16's) on my 17" wheels (optional factory 17" wheels), I've been running 44 psi for my 6 years of ownership.
What I can report is that both front and rears have worn evenly across the entire tread. One reads that if you have too much pressure, the center tire wear indicator will be reached before the edges of the tire. That has not been my experience. Also, I don't notice any difference in handling with 44 rear vs. 36 rear.
Again, why the OEM recommendation of only 36 with the 17" vs. 44 with the
16" wheels?
16" wheels?
0-60 and top speed are probably more affected by tire diameter, but the difference is so small %wise, that again, I doubt it would be a noticeable difference.
Martin has it spot on with regard to ride comfort, although I have 285/30 s on the rear of my car, and I do not find it harsh at all, but that is just my opinion. The 993 is far more comfortable than my 911 SC was.
Tires have a great affect on handling and comfort, I would focus on your needs in those categories first. Realistically how critical is 0-60 or top end speed on the street? If you are seriously tracking the car, then you shouldn't be looking at street tires anyways.
The shock/damping system can have a great impact on the ride quality as well, so the tires/size/shocks/springs/sways all have to be considered since they all impact feel of the ride. When I went from the stock shocks to the new shocks with exactly the same tires/wheels, the smoothness of the ride improved quite a bit. The stock shocks of course were totally shot.
Cheers,
Mike
When this particular TSB was issued, the PS2 was only spermatozoa
last year's TSB has the PS2 recommended here:
